T66
| posted on 2/2/11 at 06:45 PM |
Fiat 126 handbrake
My car is very tight on space, the handbrake does not have a lot of room on the floor. One of the shorty Caterham ones may fit.
Any suggestions on donor handbrakes from cars where they live under the dash - Some of the older Mercs had them.
Any others, small being the objective.
| posted on 2/2/11 at 07:09 PM |
A lot of other makes used them including Ford and BMC but I am Pretty sure it would be impossible to get through IVA
blakep82
| posted on 2/2/11 at 07:13 PM |
based on what? as long as radius requirements are met, even better if you can get it to come out on the right side of the wheel, i can't see an
issue
________________________
BigFaceDave
| posted on 2/2/11 at 07:54 PM |
We have a Hilux at work that has a handbrake under the dash to the left of the steering wheel and I have a feeling the Citroen 2cv had a simular set
up.
| posted on 2/2/11 at 07:59 PM |
Stewart has one of the Jap 4x4 under-dash 'pull' ones going spare if you need Ivan!
It's Evolution Baby!
T66
| posted on 2/2/11 at 08:46 PM |
I think I best paint the Fiat roof panel Tartan, Scott !!
I will have it !
[Edited on 2/2/11 by T66]
| posted on 2/2/11 at 08:51 PM |
I'll double check that he's still got it and get some snaps. I'll MMS them through to your phone to make sure its suitable.
T66
| posted on 2/2/11 at 09:06 PM |
cheers Scott
Sounds like a plan....
bbwales
| posted on 2/2/11 at 10:08 PM |
I fitted an umbrella handbrake on my first build, remember you will need a leverage multiplier for it. I got mine from a Toyota Hilux and paid about
£20 from a scrappy and that included the handbrake lever, the cable to the multiplier and the multiplier. If you u2u me with your email addy I will
send you pics.
regards
Bob
russbost
| posted on 2/2/11 at 10:23 PM |
I've seen an ordinary handbrake mounted sideways on (horizontally) under the dash & behind the steering wheel, can't see any reason
why it would be an IVA isssue as long as can be reached from normal seating position & it worked just fine!
