wormscoffer
| posted on 23/3/11 at 08:51 AM |
Possible donor?
I suspect this may make a good donor car - could someone confirm for me please?
1991 FORD SIERRA XR 4X4 BLUE on eBay (end time 01-Apr-11 15:34:51 BST)
Andrew
dave-69isit
| posted on 23/3/11 at 08:58 AM |
most of wot u need just need to find front uprights as 4x4 has driveshafts in the front flanges and the engines a dohc so would be a bit heavy but
thats still a good start lsd dif loads of bits to sell off too
jollygreengiant
| posted on 23/3/11 at 09:11 AM |
OK so take the balls & cage(s) out of the CV joint(s) and use them like they do on the Front of MGF's.
mcerd1
| posted on 23/3/11 at 09:17 AM |
^^ and you'll
need the larger mushroom inserts too if you do that (same as granny uprights I think)
also the 4x4 box won't be much good to you, but these are easy sold (basicaly the same as a cossie 4x4) along with the 3.92 front diff
its an ideal rear axle donor though: 3.92 limited slip with rear disc brakes - so it'll probably sell for a £150 - 300 for that alone....
[Edited on 23/3/2011 by mcerd1]
