mads
| posted on 1/4/11 at 04:05 PM |
how should i clean the universal joint on the steering?
as the title really, how do go about cleaning the gunk that is on the universal joint of the steering? is there any grease within the joint itself
that i need to be careful and can't therefore simply use some white spirit?
was also thinking of giving it a fresh coat of paint when i do the rest of it. don't think a wire brush isn't going to get into the nooks
and crannys, any suggestions on how to strip off the old paint?
[Edited on 1/4/11 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
MikeR
| posted on 1/4/11 at 05:44 PM |
wd40 to 'clean' it.
As for paint ..... id be careful as you'll be spraying paint into the joint and i'd be worried about buggering it up.
Bare
| posted on 2/4/11 at 02:42 AM |
'Most' Steering UJ's that I've seen have needle races.
In which case: No thinners, spirits OR WD40! (it's hell on bearings of any description)
Try a toothbrush and a rag ..no water or chemicals.
adithorp
| posted on 2/4/11 at 08:34 AM |
I'd wipe it with a rag to get the worst off, then go over it with another with brake cleaner or similar on, rather than wash it. There's
no practical way of re-greasing if you wash it out.
http://jpsc.org.uk/forum/
