speedstar
| posted on 10/5/11 at 11:59 AM |
Help Identify the Donor
Recently bought a part finished project, which is undergoing a compelte strip and rebuild to MSA specs, and an engine change.
Just after some help identifying what donor car it's been built around.
It has a 1.8 xflow with type9 and live rear (Don't know differences between "english" or "9 inch" etc)
What identifying parts will help pin down what car these parts came from?
rallyingden
| posted on 10/5/11 at 12:06 PM |
Live rear English the diff comes out the casing as one solid unit from the front face. Atlas axle diff has thin plate over diff internals on the rear
of the casing and they are usually of the wider type 52" flange to flange.
Hope this helps, If you post pictures I'm sure it would help identify correctly
RD
| posted on 10/5/11 at 12:43 PM |
quote: Originally posted by speedstar
It has a 1.8 xflow
really?
mookaloid
| posted on 10/5/11 at 02:16 PM |
The best thing to do would be to post some pictures up here so that the knowledgeable peeps on here can tell you what you want to know.
omega 24 v6
| posted on 10/5/11 at 09:05 PM |
A picture paints a thousand words so stick some up. I can pretty much gaurantee you it WILL NOT be a 1.8 crossflow I think the most you can get from a
xflow is 1750.
RichardK
| posted on 10/5/11 at 09:12 PM |
1.8 cvh? agree with the picture thing.
Rich
Gallery updated 11/01/2011
speedstar
| posted on 12/5/11 at 07:38 AM |
I'll get some better photos ASAP but its this one...
http://www.locostbuilders.co.uk/viewthread.php?tid=151562
Also, 1.6 XFlow. My mistake!
wz1musik
| posted on 14/7/11 at 01:08 PM |
need some photos and then can help
Kind Regards
Wesley
