liam.mccaffrey
posted on 22/7/04 at 10:36 PM |
wheelbolt spacings
i have cortina front hubs and uprights
with ford bolt spacings
is it 108 PCD?
for the rear(am building a middy) i am using the front hubs and uprights from a daewoo nubira which i think has 100 PCD
i don't want different wheels on the front to the back, as i want to put some nice alloys on eventually and then i would have to carry 2 spares
so are there any other solutions apart from getting the daewoo hubs drilled and tapped as per cortina uprights. this in itself isn't a problem
but was just checking first
[Edited on 22/7/04 by liam.mccaffrey]
Build Blog
Build Photo Album
richardR1
posted on 22/7/04 at 11:25 PM |
You're right in assuming that Ford are 108 PCD and Daewoo 100 PCD. I wouldn't worry about redrilling hubs as more and more wheels are
being manufactured with dual fitting and the 100/108 combination is the most popular as it covers most of the hot hatch fitments which is the biggest
market.
For example http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=72254&item=7910907111&rd=1 - nothing to do with me - just to give you
an idea.
phelpsa
posted on 23/7/04 at 10:28 AM |
But the Daewoo has a centre bore of 56.5 and the Ford 63.4, may me a little bit tricky.....
Adam
Mix
posted on 23/7/04 at 01:41 PM |
But you can get inserts which will reduce the Ford one to that of the Daewoo
Mick
