Author: Subject: Replacing Flywhweel
david_hornet27
posted on 19/7/11 at 02:52 PM Reply With Quote
Replacing Flywhweel
Hi All,
I have removed the original flywheel from my 2.0 Blacktop Zetec and now have a 1.8 flywheel ready to replace it.
Stupidly I went in all gung-ho and didn't make a note of where the missing hole was on the one I have removed. doh!
The engine is at TDC so my question is, what position does the missing hole need to be at when I fit the new flywheel?
Thanks for any help...
jollygreengiant
posted on 19/7/11 at 03:04 PM Reply With Quote
On most flywheel the bolt holes are not uniform in spacing, so they will only go on in one place, just try lining up ALL the bolt holes.
david_hornet27
posted on 19/7/11 at 03:47 PM Reply With Quote
Thanks Giant!
Just tried it and you are spot on. Yet another locoster helps me of a tight spot caused by me being a muppet!
sorens2
posted on 19/7/11 at 04:42 PM Reply With Quote
Remember to lighten it.
Then you get a "New engine"
Soren S2
david_hornet27
posted on 19/7/11 at 05:22 PM Reply With Quote
Soren I don't have the funds to lighten it unfortunately. Reason for the 1.8 flywheel is because it is lighter than the 2.0 one it replaced. Cheers anyway.
