Chris_R
posted on 31/7/04 at 09:43 AM |
Sierra Upright Modifications
Does anyone know if MK/GTS will modifiy Sierra uprights if you're not building an Indy or GTS Locost? Failing that, does anyone know the measure
of the taper that they need to be modified to in order to accomodate a Cortina ball joint?
Cheers guys,
Chris.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
dozracing
posted on 31/7/04 at 09:45 AM |
Hi Chris,
I'd be happy to modify them for you. Two snags, we are closed now until the 16th August, and the postage costs to and from Newcastle would be
quite a lot.
Kind regards,
Darren (GTS)
Chris_R
posted on 31/7/04 at 09:49 AM |
Wow, Darren that was quick. I'll check out the postage costs between here and Kent in the next week or so. What's the cost for having
them modded?
Thanks,
Chris.
Kelvin
posted on 31/7/04 at 10:55 AM |
I've found this website;
parcels 2 go
very handy for competitive priced shipping of heavier items.
Kelvin
Chris_R
posted on 31/7/04 at 12:35 PM |
Kelvin,
Cheers. That looks to be a bargain.
James
posted on 2/8/04 at 02:27 PM |
Chris,
You could stip the hubs/bearing out to lighten them up a bit.
James
stephen_gusterson
posted on 2/8/04 at 02:34 PM |
parcelforce bottom out at 30 kilos, but you can send that for about 11 quid
at your freindly local PO
atb
steve
Chris_R
posted on 2/8/04 at 04:32 PM |
Cheers guys, thanks for the suggestions. Just out of interest, does anyone know what's involved in the machining process? Could I do it at home
and if so what would I need?
[Edited on 2/8/04 by Chris_R]
