786evo8
| posted on 25/8/11 at 10:08 AM |
cat b used as donor?
hi guys...
can a cat b used for a donor and still maintain a age related plate?
i'd be using most of the main components from the donor ie. engine, gearbox, diff etc..
chassis of course will be scraped
thanks for the info given
jav ;-)
MLR evo forum (clicky)
phoenix70
| posted on 25/8/11 at 10:31 AM |
I thought CAT A and B write-offs had to be scrapped and crushed.
No parts of a CAT A can be re-used and a CAT B you could use parts BUT you can't use the registration to get an age related plate.
[Edited on 25/8/11 by phoenix70]
ReMan
| posted on 25/8/11 at 11:26 AM |
I'd have though you could use a Cat B and get an age related?
Maybe it's down to the DVLA on the day
www.plusnine.co.uk
bonzoronnie
| posted on 25/8/11 at 01:07 PM |
As far as I am aware
Cat A: Must be destroyed
Cat B: Can have salvage parts removed & sold but shell must be destroyed ( V5C retained by DVLA & will not be re-issued )
Cat C: Can be returned to the Road after undergiong a VIC check, DVLA will return the V5C free once the VIC is passed.
Cat D/E can be returned to the road without the need for a VIC but if you do not have the V5C a replacement fee is payable.
In theory I suppose you could use the parts of a Cat B vehicle as a single donor source for major components but I have a gut feeling that without the
V5C as proof, you may have problems convincing DVLA that this is the case
Is there such thing as a DVLA official working with good old fassioned common sense, an invoice from a licenced salvage agent detailing serial
numbers, reg number & vin number should be good enough !!??
Been a couple years since I last traded in the salvage market so might not be fully up to date with things
[Edited on 25/8/11 by bonzoronnie]
Flynn
| posted on 24/10/11 at 04:13 PM |
You could use the parts, but it will go onto a Q plate
steve m
| posted on 24/10/11 at 04:20 PM |
I have bought several cat c, and never needed a vic check, but i always buy whaen a v5 is with the car
