Steve Hnz
posted on 2/8/04 at 12:45 PM |
weber 32/36 choke housing
I`ve just bought a weber 32/36 DGVA & manifold to go on my bitsa engine(1600 xflow) & it seems to be in good nick apart from what I assume to
be the hot water jacket missing from the auto choke. At this place & comparing it to the one on my Sierra work hack, it has a conical projection
with radial ribs & a threaded hole in the centre of the projection which I assume the water jacket should screw on to.
Is it possible to get them seperately, or will I have to look out for a second hand one, alternatively, can you still get manual choke conversion
kits?
posted on 2/8/04 at 01:03 PM |
I got a manual choke conversion kit for around £15 in my local motor factors - not too hard to fit, if you've got a reasonable amount of
mechanical sense.
The worst bit was the instruction sheet - very small writing and far too much detail! Better than not enough, though.
Steve Hnz
posted on 3/8/04 at 09:52 AM |
Thanks David, at least I now know they`re available, I just need to track down soneone who has them/ can get them on this side of the globe. Do you
recall if it was a weber kit or an after market kit? Still be interested to know if I can get the hot water thingy, the wallage book seems to like
them though I lean toward manual. It`ll most likely come down to cost.
posted on 3/8/04 at 09:55 AM |
It was after-market - might be worth a Google search.
phil m
posted on 4/8/04 at 01:13 PM |
I managed to buy one ---- I found the vplace in an add in a kit car mag --when I get home I'll send you the address
In Cyprus at the moment-home on thurs
Phil
Steve Hnz
posted on 5/8/04 at 05:20 AM |
That`d be great Phil, hope Cyprus is warmer than where I am just now. Cheers, Steve.
MikeR
posted on 29/5/05 at 09:36 PM |
did anyone have any luck with this?
Really need to convert my carb to manual choke so everything will fit!
Marcus
posted on 30/5/05 at 09:24 AM |
Making a manual choke is a piece of pi**.
Coming out of the side of the carb is a brass pin. Using the insides of an electrical screw type connector, screw it onto the brass pin. Cross drill
the other side of the connector to take a cable (solid choke cable, about £2 from Halfords). Use throttle cable bracket as a cable stop, and Bobs your
uncle!
I'd love to post a pic, but I'm off to the Coast now!
Marcus
Marcus
Because kits are for girls!!
MikeR
posted on 30/5/05 at 10:07 PM |
looked at that but i guessed the movement of the choke would be too small to be controllable..
i was also worried about effort to move it but thinking about it now, if a bi-metal strip can do it ....... i should be able to manage.
might try the proper route first then go locost afterwards
