teamhampshire
| posted on 11/6/12 at 07:35 PM |
how do you tell the DVLA you are breaking a donor
Hi all,
i am very new to all of this (still haven't chosen a donor car)
i was thinking today about what donor to get and then it occurred to me, after stripping what ever donor i do end up getting down to the bits i want
and need.
i would be left with a shell (after i have sold everything else on ebay), so i could take the shell to the local scrap metal merchant and get rid of
it.
but how do i declare that the car no longer exists?
normally when you scrap a car you just take it to a scrap yard and they deal with the dvla.
any ideas would be great.
ps just read the thread below, sorry. ps i didnt want to keep the plate as i like Q
[Edited on 11/6/12 by teamhampshire]
designer
| posted on 11/6/12 at 07:40 PM |
You fill in the bit on the V5 saying you have scraped the vehicle.
mark chandler
| posted on 11/6/12 at 07:42 PM |
Make sure you do this, although you may get the sorn police after you with a fine !
loggyboy
| posted on 11/6/12 at 07:45 PM |
When you register the car, using the donors cars v5 to declare what pasts you used, the DVLA will automatically register it as scrapped.
Just hold on to the all the paperwork and keep sorning it as long as you are building it.
Mistral Motorsport
stevegough
| posted on 11/6/12 at 07:52 PM |
No, you don't tell them its scrapped.
You put it on SORN, (you may need to renew it once or twice as SORN only lasts 12 months).
Take off the bits you want, save anything that might be useful.
Remove the ID VIN plate ( I cut out most of the slam panel ) and don't forget the number plates and the VIN by the driver's seat.
Then, when you go to register your kit, you will still have the V5 from the Donor to help with the age - related plate. At that point you then
declare the car scrapped - produce the receipt from the weigh - in of the cut-up shell to prove you have disposed of it responsibly.
(If you have left any ID on it when you weigh it in, the scrap merchant has to inform DVLA that they have recieved a scrap car and DVLA will scrap
your Donor, so ensure you remove all ID!!)
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
AdrianH
| posted on 11/6/12 at 07:54 PM |
As above I would suggest you do not scrap the car and tell DVLA.
Break the car, remove all signs of the Vin/Chassis number from the vehicle and scrap the shell as normal metal.
I handed over the old V5 when registering my kit after IVA and it caused no problems.
From that point on I no longer got reminders to sorn or tax the old car. I did have a receipt for the old chassis from a metal recyclers as a way to
show the shell had been disposed of properly, that was also presented to the DVLA.
Adrian
Why do I have to make the tools to finish the job? More time then money.
Ben_Copeland
| posted on 12/6/12 at 05:43 AM |
The new v5c's don't allow you to tick the scrapped box anymore.
As Steve says keep it till you IVA your car then the DVLA will scrap it for you.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
alladdin
| posted on 1/12/12 at 09:09 PM |
when you take the shell and v5 to registered scrap merchant (or he collects) he will issue you with a "destruction notice".
this is your proof, keep it.
stevegough
| posted on 1/12/12 at 09:50 PM |
Don't think you can have read the thread properly.
When you weigh in the shell, YOU KEEP THE V5.
Remove all identification from the parts you are scrapping.
If you scrap it officially at this point, you won't be able to get an age-related plate.
The V5 is then presented to DVLA together with your IVA certificate, receipts and application for registration documents.
The V5 proves the 'source' of major parts - axles, transmission, steering and engine (in some cases).
If you can't prove the origin of the major parts, you will end up with a 'Q' plate (which means 'Questionable origin'
[Edited on 1/12/12 by stevegough]
Luego Locost C20XE.
alladdin
| posted on 1/12/12 at 09:57 PM |
i answered this question,,, didnt see any others?
the scrap merchant does the dvla bit.
while its yours you sorn it, but that wasnt the question.
alladdin
| posted on 1/12/12 at 09:58 PM |
read the thread
he WANTS a Q plate
stevegough
| posted on 1/12/12 at 10:15 PM |
read the thread
he WANTS a Q plate
Makes you wonder why I bother. - Ok, Ok, I have now re-read his question. I stand corrected.
(but the advice still stands for those who want an age-related plate).
Luego Locost C20XE.
alladdin
| posted on 2/12/12 at 05:08 PM |
and usefull info too as i didnt realise it was still possible to keep a donor plate. all was in jest by the way
stevegough
| posted on 2/12/12 at 08:03 PM |
You don't keep the donor plate, per se - you get a plate bearing that year's letter.
Luego Locost C20XE.
