Slimy38
| posted on 4/8/13 at 02:07 PM |
Seatbelt parts ok for IVA
Here is the seatbelt as it's been removed from the donor;
  Donor seatbelt
Is it ok to be reused for IVA? Obviously it needs a good scrub up. The upper mounting has a long bolt through the metalwork pictured, can all that be
reused?
Does anyone know what the bit of wiring is for though? I've not seen wiring on this side of a seatbelt, only on the catch side where it was for
a pretensioner.
big_wasa
| posted on 4/8/13 at 03:43 PM |
If the real is not mounted at exactly the same angle as the donor it wont work. four point harnesses are not every ones cup of tea but I really would
think about a set for iva. Tried and tested.
Slimy38
| posted on 4/8/13 at 04:29 PM |
Yeah I saw that, there is a 'float' type device in the ratchet mechanism that only works when it's fully upright. The fixings are at
the right angle though so they should mount quite easily.
