Chris Ridgers
posted on 28/10/14 at 10:04 AM |
RTM's workshop clear out.
Had a clear out in the workshop yesterday, listing items here first before heading to ebay. Most items are new or fitted once then removed. Prices
included recorded delivery. Or if you which to collect I'm based in Maidenhead. apologise for the size of the photos.
Can take payment via paypal or cash on collection feel free to message me any questions
Brand new Yamaha R1 wing mirrors IVA friendly £30
Brand new zetec blacktop dipstick holder and dipstick £45
Brand new Rix Engineering Hydraulic Handbrake Assembly £150 cost as seen below looking for £95
http://www.demon-tweeks.co.uk/motorsport/hydraulic-handbrakes/rix-engineering-hydraulic-handbrake-assembly
New 2.0 Zetec NRK spark plugs and leads £25
New battery kill switch with two keys £10
New wiring harness for spot lights - left over from a defender project £10
Rear Fog light- fitted ones for IVA then removed £6 ****SOLD****
Ring driving Fog Spot Lamps Pre wired fitting kit new £10
Electric demister heater comes as a pair £60 new looking for £35 ****SOLD****
Brand new fuel exhaust can brushed stainless steel 51mm / 2" (Internal Diameter) Slip On Exhaust with removable baffle.
Sleeve is 450mm long total length is 560mm unused in Mini project £120
Mono Quark Steering Wheel - 350mm diameter was fitted to LB2 show car for one event then removed £120 new looking for £60
Ford Anglia type 9 speedo cable for cortina mk1&mk2 o type 9 gearbox cable is £69" long £20
Also have Speedo Cable - 5 Speed - VDO seen below brand new £20
http://www.caterhamparts.co.uk/product.php?id_product=2645
HEL custom brake lines in Oranage with banjo fitting and female swivel circlip 440mm long cost £50 looking for £25
Ali gearlever and handbrake surrounds, gearlever 17cm x 13.5cm handbrake 16.5cm x 7cm £15
New Slimline Fan 167mm (6.6inch) Pull will comes with fan pin kit £45
****SOLD********SOLD********SOLD****
[Edited on 28/10/14 by Chris Ridgers]
theprisioner
posted on 28/10/14 at 10:11 AM |
Can you tell me the outside diameter of the can?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Chris Ridgers
posted on 28/10/14 at 10:20 AM |
it's 113mm
tompat3463
posted on 28/10/14 at 10:48 AM |
hi mate. can you post out the demisters ? if so Ill snap those up..or if your beat ill arrange courier.
thanks Alan
Chris Ridgers
posted on 31/10/14 at 07:57 AM |
Demisters, Fog light, Leads & Spark plugs sold
tompat3463
posted on 31/10/14 at 09:08 AM |
Received the goods. Thanks mate
