spiderman
| posted on 5/4/15 at 08:26 AM |
ST24 RWD conversion
Just picked up a Modeo ST 24 with 78k miles on it, for my favourite price,free. It needs a N/S sill replacing, 2 new included in the price.
I would at some point like to use the engine for a RWD conversion to fit into a Triumph GT6.
Can anyone point me in the right direction as to what gearboxes might fit and any other mods I might require to run it in my proposed project.
Spider
[Edited on 5/4/15 by spiderman]
Spider
big_wasa
| posted on 5/4/15 at 08:56 AM |
You can use jag bits like sump and gearbox but the ratios are said to make an mt75 look like a race box. There is a guy selling adapter plates for a
lot of fords to take the very cheap and strong rx8 6 speed.
Induction, I would start with what you have. Should be 200 bhp with a few breathing mods and decat.
200 bhp for free free free just by using the oem ecu
spiderman
| posted on 5/4/15 at 09:50 AM |
Funnily enough I have a MT75 gearbox (not sure which model it's from) and alas had to pay £70 delivered.
Do you have any details on the guy selling adapter plates?
Spider.
Spider
Ugg10
| posted on 5/4/15 at 09:53 AM |
Http://www.turbosport.co.uk/showthread.php?t=500016
This is the thread on rx8 swaps, p9cyo is the guy's username.
Induction wise, there is a thread somethere on the Web about a lotus esprit with the jag version fitted, he started using the triumph triple tbs
(similar to clairetoo's klde installs) with a thick adaptor plate to get the ports to match and then went on to the st220 plenum to get overhead
space. If you go aftermarket ecu tand keep the engine stock hen you need to sort out the secondary butterflies that change the inlet tract length.
You could always use a cosworth t5 gearbox but will need a bellhousing or adaptor plate and the clutch sorting, you may be lucky and be able to use a
cossy plate and the st24 release housing as they are both 240mm. Sorting out starter motor might also be fun.
I think there is one of these fitted to a fury somewhere abouts.
[Edited on 5/4/15 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Badger_McLetcher
| posted on 5/4/15 at 05:21 PM |
I'm currently putting in an AJ30 from a Jag S-type. I think the S-type gearbox will marry up, however you would also need the clutch, flywheel
and starter from the S-type to use it. I'm using an X-Type sump as it's a better layout than the S-type, not sure about the ST24 one.
Barring that you are into adapter plate territory, it may be worth looking at this bloke:
http://www.ebay.co.uk/itm/Type-9-Conversion-Plate-RX8-fit-any-Engine-FREE-POSTAGE-Or-Collect-CHESHIRE-/391103715185?
Inlet wise it wouldn't be too difficult to use some Triumph TB's - in fact I have a set of 6 I'd be willing to sell off. I found
them to be too small for the AJ30, but they may be OK for the 2.5 litre version. Possibly an easier approach is to use the ST220 inlet manifold, which
is a smaller item I think.
Here's some further food for thought:
http://www.thelotusforums.com/forums/topic/8126-30-v6-conversion/
http://www.thelotusforums.com/forums/topic/29886-30-jaguar-v6-duratec-in-s3/
http://s74.photobucket.com/user/a_morti/library/Tona/T595%20throttle%20bodies?sort=3&page=1
Ugg10
| posted on 5/4/15 at 06:50 PM |
I think the guy in the eBay link is the same guy on turbosport, both in Cheshire and similar photos.
big_wasa
| posted on 5/4/15 at 07:02 PM |
I didn't realise he had them on eBay already. Cheers for that. Mind you price has gone up 50% to cover ebay costs.
spiderman
| posted on 5/4/15 at 07:46 PM |
Well as ever this forum comes up trumps, that's why I like it so much, so much knowledge that people are willing to share.
Many thanks for the info guys, looks like I will have some reading and research to do over the next day or two. Will I ever get the Locost finished?
15 yrs and counting I WILL get it finished this year, I WILL, I WILL, I WILL.
Spider
spiderman
| posted on 9/4/15 at 12:18 AM |
Not sure I have the funds for a set of throttle bodies at the moment, after shelling out so much for the car. But as a matter of interest what
Triumph are they off and how much would you want for them?
PM me if you prefer
Many thanks
Spider
Spider
| posted on 9/4/15 at 10:43 PM |
There's a mk1 escort in the latest ppc running one rwd.
Check it out!
spiderman
| posted on 10/4/15 at 04:42 AM |
Check it out!
is it this one?
http://www.talkford.com/community/topic/218479-st200-in-a-mk1-escort/
Spider
| posted on 10/4/15 at 01:34 PM |
Check it out!
is it this one?
Yep, thats it, its in the April issue complete.
