micksalt
posted on 26/8/15 at 01:10 PM |
MX-5 Hub Nut Dust Caps
So far, I've had no problems finding sources for the parts I need to restore the MX-5 bits going into my Vortx. However, the dust caps (Mazda
Part B455-26-071) that prevent dust ingress into the hub nut and wheel bearing are proving very tricky to find in the UK. Any ideas where I might find
these?
Thanks in advance.
prawnabie
posted on 26/8/15 at 01:28 PM |
autolink?
micksalt
posted on 26/8/15 at 01:31 PM |
quote: Originally posted by prawnabie
autolink?
They've served me well for a lot of bits, but not these. I wonder if it's just a case of measuring the aperture and ordering generic
grease caps?
Slimy38
posted on 26/8/15 at 01:32 PM |
Hmm, this post made me think about my donor... I didn't have dust caps on any of the hubs!!
rash12
posted on 26/8/15 at 01:35 PM |
try living 3000.co.uk says theres some on there ?
micksalt
posted on 26/8/15 at 01:40 PM |
Is that http://www.living3000.co.uk/ ? What search terms did you use?
micksalt
posted on 26/8/15 at 01:42 PM |
I had them on three of the hubs, but ended up mashing them on removal due to corrosion. Apart from the seal between the hub, brake-disc and wheel,
there's not a lot stopping dust and water getting to the hub nut and subsequently the bearing.
Adamirish
posted on 26/8/15 at 03:12 PM |
There was some in the bearing kit I bought for my mx5. If you are replacing the bearings then buy a bearing kit rather than just the bearing. Failing
that, ring mx5 parts. Good to deal with and very knowledgable from my dealings with them. In fact, I know I have a bearing in my garage but unsure if
it's a kit or not.
MK Indy 1700 Xflow
Adamirish
posted on 26/8/15 at 03:27 PM |
Are these the ones?
http://www.mx5parts.co.uk/front-cover-mk1-25-p-1885.html
MK Indy 1700 Xflow
micksalt
posted on 26/8/15 at 03:55 PM |
quote: Originally posted by Adamirish
Are these the ones?
Top of the class. How I missed those is beyond me. Thank you very much indeed ![](/images//smilies/bigsmile.gif)
Adamirish
posted on 26/8/15 at 04:09 PM |
Are these the ones?
No problem at all. Anything mx5 related just ring them, they are very very good at what they do.
MK Indy 1700 Xflow
