Slimy38
posted on 25/7/18 at 05:42 PM |
'Sharpening' phillips screwdrivers
Some of my Philips screwdrivers have seen better days, and are as good at chewing up screws as they are actually screwing them in. They've all
gone the same way, the four 'blades' have worn but the pointy bit is still there. This means that the screwdriver head hits the bottom of
the screw before it touches the sides.
So, is there a way of restoring them? My first thought would be enthusiastic use of a fine file to dress the blades and bring it back to more
'screwdriver-like'. Alternatively, I could probably get them working again by just filing the point down a bit and allowing them to sit in
the screw a bit better. I've recovered a few flat drivers but they're infinitely easier.
Any ideas?
fazerruss
posted on 25/7/18 at 06:46 PM |
Bin. Nothing else you can do and not worth it. If the shank was removable then the tip can only be re cut accurately on a tool cutter grinder. Problem
is the handle prevents it going in the collet.
"if assholes could fly this place would be an airport"
SJ
posted on 25/7/18 at 07:31 PM |
Buy your Philip some new ones for his birthday? ![](/images//smilies/bigsmile.gif)
adithorp
posted on 25/7/18 at 07:54 PM |
Are you sure the screws are phillips heads? Most are Pozi-drive and using a phillips driver on a pozi screw will mess it up.
http://jpsc.org.uk/forum/
posted on 25/7/18 at 07:56 PM |
Throw them away and buy some new ones.
Buy some decent ones and look after them.
Make sure you use Philips and Pozi-Drive screwdrivers on the correct fasteners. My wife for one is terrible at assuming one will work on the other
and not hurt the tool or fastener.
Slimy38
posted on 25/7/18 at 09:22 PM |
That's the word I was after, thanks. I use Phillips because that's what I could remember, but they are actually pozidrive.
adam1985
posted on 26/7/18 at 01:25 PM |
Ive often found cheaper screwdrivers cause the end to point after time. Buy a decent set and they will last well. My weapon of choice is the stanley
fat max screwdrivers.
posted on 26/7/18 at 01:35 PM |
WIHA screwdrivers are one of my favourites at the moment.
Available from Screwfix, not bad price and work/last really well.
Many of them have a hex section at the top of the metal part so you can use a spanner to apply more torque if required.
https://www.screwfix.com/p/wiha-softfinish-screwdriver-ph-2-x-100mm/758
7g
[Edited on 27/7/18 by nick205]
posted on 27/7/18 at 07:59 AM |
Another screwdriver brand I'm quite keen on is WERA
http://products.wera.de/en/screwdrivers.html
Got several WERA screwdrivers and they work very well - they last too!
ReMan
posted on 27/7/18 at 08:44 AM |
I like these:
https://uk.rs-online.com/web/p/products/3100355/?grossPrice=Y&cm_mmc=UK-PLA-DS3A-_-google-_-PLA_UK_EN_Tools-_-Screwdrivers_And_Screw_Extractors%7C
Screwdriver_Bits_And_Bit_Sets-_-PRODUCT+GROUP&matchtype=&gclid=EAIaIQobChMI-er-4_G-3AIVir_tCh1SlAqFEAYYCCABEgKQPfD_BwE&gclsrc=aw.ds
www.plusnine.co.uk
