Lotusmark2
| posted on 26/1/05 at 08:11 AM |
pedal box
Hi all
has anyone got some suggestions as to a bottom mounted pedal box (as per race type pedal box)
Mark
alfasudsprint
| posted on 26/1/05 at 10:10 AM |
Mark,
I am fabricating floor mounted pedals because it will give me greater leverage and the pedal pad at the corect height for my foot, whereas before the
effort on a non servo'd system was too great, with a ratio of 1:3, should be 1:5 or 6, as I read on here somewhere.
Andybarbet
| posted on 26/1/05 at 04:28 PM |
I've got the Luego floor mounted pedals with twin master cylinders and bias bar, very well made etc, Car builder solutions (www.nfautos.co.uk)
also sell the same arrangement for £98 - not including the master cylinders which are about £35 each, if thats any help ?
If your after making your own, i've not got a clue !!
| posted on 26/1/05 at 09:20 PM |
Just to point that master cylinder dia is very important when working ouy pedal ratios.
ALL cars with servos use a bigger dia master cylinder than those without --- the diiference in area is quite significant and this has a major effect
on pedal effort.
Humbug
| posted on 6/2/05 at 11:19 PM |
(Vaguely) related to this topic - I bought a ST rolling chassis with floor mounted pedals (look similar to the Luego ones) already fitted and master
cylinders attached. However, the brake pedal has no bush/insert so the threaded bar rattles around, and I can't see an easy way of taking it off
to fit a bush, assuming one is needed. Any ideas? Would I take the master cylinders off? If I do, can I safely unbolt the brake pipes and reconnect
them afterwards?
Also, how do you adjust the adjustable bias between front and back brakes? It looks pretty permanent and I have heard that you sometimes need to
adjust the bias for SVA
Hoping for some help...
