omega 24 v6
| posted on 26/4/05 at 07:29 PM |
wHATS WORTH TAKING
I've just been to look at a sierra thats scrap but the guy wants to keep the engine,box,backend,steering rack and uprights. Anything else i want
is mine.
I'm gonna have the steering column and pedal box if its any use but wondered if there is anything else i should consider. Should i take the
master cyl as well or is it no use because of the servo. I might take the switches as well.
Any thoughts on this one guys.
flak monkey
| posted on 26/4/05 at 07:41 PM |
Master cylinder detaches from the servo, so take it, and it has a resevoir with the low level light for SVA.
Steering column and downlink is a good idea.
Pedal set if you are going to adapt them to make top mount pedals.
Wiring loom if you want to make your own.
Wheels for something to move it around on when you are building?
Sera
http://www.motosera.com
omega 24 v6
| posted on 26/4/05 at 07:49 PM |
cheers david i wasn't sure about the servo but i'll have the master cyl and warning switch. I'm making my own loom anyway
(it'll just be like another working day). had'nt hought about the wheels so thanks for that.
flak monkey
| posted on 26/4/05 at 08:25 PM |
Though of more...
Hand brake mechanism
Any interior trim that could be hand (rear view mirror etc)
Side repeaters?
Fuel filler down pipe (from filler to tank)
Just have a look around the car and take anything you think could come in handy...
Sera
smart51
| posted on 27/4/05 at 07:05 AM |
Horn
Seat runners?
fuel pump?
tks
| posted on 10/5/05 at 09:52 PM |
pff..
bulbs?
license plate light?
coolant res?
relais
fuse box
pff plenty of stuff...
you are gonna forget..
TKS
