Author: Subject: Have I bort a lemon ?
big_wasa
posted on 12/6/05 at 01:31 PM Reply With Quote
I really wanted some capri 4 spoke alloys for my project and picked up 4 id won on ebay ..They came with no nuts ..I have some brand new nuts(capri flat washer type) but they in no way fit the alloys..The alloys have a huge hole of about 20mm and a small taper .Looks like bugger all to hold wheel on to me..
Question have I bort a lemon Or have I got the wrong nuts..
When I say lemon I suspect that someone has drilled the alloys out to match the nuts? all 4 wheels are the same
Can anyone show me a pic to put my mind at rest before I carry on shot blasting them all....
big_wasa
posted on 12/6/05 at 01:32 PM Reply With Quote
pic 2
tom_loughlin
posted on 12/6/05 at 01:35 PM Reply With Quote
my sierra alloys come with tapered holes in them - the wheel nuts take a 19mm socket, and have a kind of tapered washer to locate to the wheels.
hopefully that will help.
the wheel nuts you have dont look like any of the 3 ford sets i have, all of mine are tapered - including a set i bought with aftermarket wheels.
All the best,
Tom
[Edited on 12/6/05 by tom_loughlin]
planetester
posted on 12/6/05 at 01:47 PM Reply With Quote
you have nuts for RS alloys, capri laser nuts are tapered the same as sierra,
posted on 12/6/05 at 02:09 PM Reply With Quote
Your nuts are the wrong shape - you need tapered one's. I've have three Capri's, but I've never had nuts like those even with the same looking wheel (1981 - Capri 2.0S).
Get the different nuts and you should be ok.
posted on 12/6/05 at 02:10 PM Reply With Quote
I can see the offset now, get some taper nuts and you'll be o.k. The hole in the rim is about 20mm but the wheel locates on the centre boss and the taper centres the stud.
phelpsa
posted on 12/6/05 at 02:24 PM Reply With Quote
They look pretty lemon coloured to me
You need the capri laser nuts, not RS ones as you have.
Adam
big_wasa
posted on 12/6/05 at 02:26 PM Reply With Quote
Hi they are 13x6jxch19...
I was under the impession the RS wheels and the Laser wheels were one and the same.I know the fiesta wheels being fwd had dif ofset also know they did a 7" version... Looks like my mistake I was under the impresion there should be more metal around the stud? or bigger tapper?
Im pleased as I have a set of pug 1.9 gti wheels that I moded to take the nuts in the pic ,so they could be mounted on ford studs.
Ive had one of those weeks(had my tin-top spanked) and assumed the worst
So what nuts do I want? Standard ford alloy cone type 60 deg tapper?
big_wasa
posted on 12/6/05 at 02:28 PM Reply With Quote
Adam
Not for long
phil m
posted on 12/6/05 at 02:36 PM Reply With Quote
bought mine from www.speedshack.co.uk
phil
Volvorsport
posted on 12/6/05 at 02:46 PM Reply With Quote
im sure the RS alloys had a steel insert , these can come loose and cause vibration , maybe you have got those with the wheels ?
www.dbsmotorsport.co.uk
getting dirty under a bus
big_wasa
posted on 12/6/05 at 02:52 PM Reply With Quote
didnt the RS wheels have no inserts ? like the pug wheels .Hence the flat washer type nuts?
stevebubs
posted on 12/6/05 at 04:09 PM Reply With Quote
Escort RS Wheels had a flat nut
Capri Laser (which you have) have a tapered nut.
I'd second Speedshack in West Drayton, plus I *know* they've got a full set of bolts in - I was in there at 5.00pm yesterday asking a very similar question.
Just tell them Capri Laser onto Sierra / Mk II Escort hubs and they'll give you the right ones.
About £2/throw I think, though so £32 the set.
Stephen
Stephen
Mark Allanson
posted on 12/6/05 at 04:43 PM Reply With Quote
I found 15 at my local scrapyard, Jolsen found the 16th!
They are quite common, they are on Sierra Ghias, Escort Ghias, Capri's and many more I am sure
JohnN
posted on 12/6/05 at 07:15 PM Reply With Quote
I seem to remember back in the late 70's when I had a set of that type of alloy wheel, that they had no taper, the nuts - had just a flat seat??????
John
stevebubs
posted on 12/6/05 at 07:40 PM Reply With Quote
John
Those would be the true "RS" alloys not the "laser" ones. They look the same but have slight differences - the biggest being the nuts.
DavidM
posted on 12/6/05 at 07:46 PM Reply With Quote
Got the nuts for my laser alloys from Lolocost. £1 each.
Proportion is Everything
posted on 12/6/05 at 09:20 PM Reply With Quote
Beware if they are the ones I think they are I am pretty sure the taper isn't right for the Ford alloy wheel --
richardR1
posted on 12/6/05 at 09:29 PM Reply With Quote
Check out http://www.domsat.co.uk/pages/wheels.htm
If you look just over half way down at the picture of the three wheel nuts you want the one on the left. Known as an RS taper nut. They have a tapered collar on them that is free to spin. They are used on most XR/RS Fords.
DavidM
posted on 12/6/05 at 11:02 PM Reply With Quote
Yep, they're the same as the ones I've got from Lolocost. They fit fine.
