slaggywelder
posted on 17/6/05 at 08:53 AM |
Donor, donor, donor
Hello all,
Can a Mk2 Cortina be used as a donor, as I have been offered one at low price as the body is beyond restoration.
Mark
Arthur Dent
posted on 26/6/05 at 03:07 AM |
MKII Cortina has front struts. The engine would be useable especially if its a cross flow.
'The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go
wrong goes wrong, it usually turns out to be impossible to get at or repair.' Douglas Adams
Mark Allanson
posted on 26/6/05 at 10:34 AM |
Only the very last of the Cortina II's had a crossflow with a 5 bearing crank, the early ones had a 3 bearing (def no no)
gazza285
posted on 26/6/05 at 12:40 PM |
All crossflows have a five bearing crank. It was some of the pre crossflow engines that had a three bearing crank.
escary
posted on 26/6/05 at 08:33 PM |
yes
slaggywelder
posted on 26/6/05 at 10:24 PM |
Thanks folks,
I knew about the struts being no use (forum search), but wasn't sure about the engine (1600E), as it's so cheap it's worth a shot
and strip down.
Mark
locost_bryan
posted on 27/6/05 at 03:30 AM |
donor for original Formula Fords IIRC - should be a goer
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
