Big Ali D
posted on 30/8/05 at 04:50 PM |
Mc sorley 7+442 with capri running gear?
Please can i have some advice on my first project,
I intend to use 2ltr Pinto running gear in a McSorley 7+442 however i am still unsure if this is the best option for me
Please can you tell me the pros and cons of my combination .
Volvorsport
posted on 30/8/05 at 06:22 PM |
it will all fit !! if youre using a chassis that big .
my volvo based one is slightly wider than sierra IRS
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 30/8/05 at 06:24 PM |
i assume you need +442 cos you're a big guy? so thats not a choice really. And the pinto is as good an engine as any really, horses for courses.
You could argue/discuss engines all day and never find a consensus.
So just go for it, you'll love it!
James
posted on 30/8/05 at 08:01 PM |
Is the Capri axle +4" or +2" relative to the escort?
I should know- but I've forgotten!
If it's +2" then you'll need extra-narrow arches and might have a problem with the trailing arms hitting the wheels.
If it's +4" then you're ok but be prepared for maybe harder work when sourcing your bodywork with a wider chassis.
HTH,
James
[Edited on 30/8/05 by James]
- Muhammad Ali
big_wasa
posted on 30/8/05 at 08:13 PM |
most but not all capri axles are 4" wider
Volvorsport
posted on 30/8/05 at 11:08 PM |
no problem sourcing +4 bodywork
James
posted on 30/8/05 at 11:39 PM |
Huh!
James
- Muhammad Ali
Volvorsport
posted on 31/8/05 at 12:04 AM |
well , if its wrong , ive only got myself to blame .
