romer
| posted on 6/11/05 at 07:01 PM |
Steering column and rack.
Just wondered if someone would be kind enough to please enlighten me ref the following -
Sierra
Does it matter which steering column and rack to use in a type 7 kit.
ie Can a PAS type column be used?
Can a PAS type rack be used?
Or is this too difficult a question due to different models or other possibilities/issues?
Will appreciate your views and thanks in advance.
Romer
[Edited on 6/11/05 by romer]
flak monkey
| posted on 6/11/05 at 07:04 PM |
You can use any column you like as far as I know.
You want a non assited rack though. Tricky to fit the assisted one in, though its possible. And not possible to use it without assistance without
major modifications.
Sera
http://www.motosera.com
| posted on 6/11/05 at 07:29 PM |
The bottom link for the power assisted rack will not fit the unassisted rack, the spline is a different size. The one I found was bigger for PAS. The
top column is same but the PAS I found was an adjustable which can be a pain or an advantage.
romer
| posted on 6/11/05 at 11:46 PM |
Ok guys, thanks for those coments - looks like I need a non PAS car then.
Romer
