Chris Bellamy
| posted on 18/12/05 at 04:17 PM |
2l estate Pinto sierra
Ive found a 2 litre estate Pinto sierra for sale. £40. Will this be any good. Is an estate better than a hatchback?
Thanks Chris
dave r
| posted on 18/12/05 at 04:21 PM |
rear end is slightly different i belive but nothing half hour with a grinder & welder cant correct
Chris Bellamy
| posted on 18/12/05 at 04:28 PM |
So the estate has got a wierd back end. In what way? Surely it cant be different in all the working parts?
Chris
Chris Bellamy
| posted on 18/12/05 at 04:29 PM |
And will the donor car work?
Chippy
| posted on 18/12/05 at 06:06 PM |
I assume that your asking if it will work as a donor vehicle, the answer is certainly, especialy if it has a manual g/box. The only thing that may be
diferent to the car is the back axle ratio, and I don't know if the estate has a lower ratio.
| posted on 18/12/05 at 06:19 PM |
the ratio is unlikely to be different. The trailing arms and shocker arrangement is different, but the running gear is all the same.
andyharding
| posted on 19/12/05 at 02:07 PM |
I've used a 1.6 Pinto Estate as my donor and I'll be on the road over xmas (fingers crossed).
smart51
| posted on 19/12/05 at 03:25 PM |
Some estates have a higher numbered diff (3.92 often) to keep the revs up for pulling all that extra weight. That may only apply to the smaller
engines.
andyharding
| posted on 19/12/05 at 05:14 PM |
engines.
Yup, that's what I've got. And the long stoke engine. Can light the tires in 3rd gear!
