Author: Subject: Chemical Blackening
TimC
posted on 26/1/06 at 01:41 PM Reply With Quote
Chemical Blackening
Just a general interest-type question here -
Have seen 'Chemical Blackening' of parts talked about on the MNR website.
Can anyone explain what this involves? Presumably some sort of specialist company could do this also? How resistant is the finish to corrosion etc?
I just have no idea abou this process....
posted on 26/1/06 at 01:48 PM Reply With Quote
Think Frosts will sell you a DIY kit -- istr a Phoshate coating similar to that use on nuts and bolts and re-ground camshafts..
flak monkey
posted on 26/1/06 at 01:54 PM Reply With Quote
We have chemical blacking at where I work in the summer.
Its (well ours) is a 4 or 5 stage process. The first of which is a cleaning stage. The rest are different chemical treatments.
Sure you will find loads of info on it on the web somewhere.
Sera
http://www.motosera.com
posted on 26/1/06 at 01:55 PM Reply With Quote
Link to Frosts product page
http://www.frost.co.uk/item_Detail.asp?productID=8253
posted on 26/1/06 at 02:02 PM Reply With Quote
If you mean the kind of finish commonly found on socket cap bolts, it's not very rust resistant. Alright for indoor use, but not much good outdorrs or on a car (IMHO).
Nick
NS Dev
posted on 26/1/06 at 02:17 PM Reply With Quote
That's right, it will rust, but whether that worries you or not depends I suppose!
I will be using them on my car in a few places!
oliwb
posted on 26/1/06 at 03:01 PM Reply With Quote
Can't you quench cherry red hot steel in old black used engine oil to give it a kind of blackened finish??? Oli.
posted on 26/1/06 at 04:30 PM Reply With Quote
Doesn't have to be red-hot - just hot enough so that the shiny metal starts to colour ('light straw' they used to call it). Dip it in the old oil, pull it out and let it drain, then re-heat. Repeat until you get the colour you want.
DISCLAIMER! This is what I did - there's lots of smoke, possibly flames, so there's risk involved (especially if the oil has only just been drained out of the engine). Be careful, do it outside, wear suitable protection, and, if all goes wrong, don't blame me!
[Edited on 26/1/06 by David Jenkins]
andyace
posted on 26/1/06 at 06:49 PM Reply With Quote
yea, used to do it in metalwork all the time to blacken metal, and yes every so often the oil goes up in flames, great fun when u r at school not so much fun in the garage.
