austin man
posted on 28/2/06 at 11:42 PM |
zetec sump
Currently building a type 7 will be fitting 1.8 zetec. I am aware that the sump will need modding for clearance or is there an alternative apparently
they are very pourous and a pain to weld. I have heard that vthe CVH sump may fit any ideas ????
Mr G
posted on 1/3/06 at 12:40 AM |
A sierra 1.8 cvh sump and pickup pipe will bolt straight up to the zetec
stevebubs
posted on 1/3/06 at 01:37 AM |
If you fettle it with an angry grinder...
donut
posted on 1/3/06 at 07:29 AM |
You will need to drill a couple holes in the block and tap them as there are more holes in the CVH sump than on the Zetec block.
Surrey Dave on here has performed this operation.
Mr G
posted on 1/3/06 at 09:53 AM |
I'm sure austin man would like to know exactly what fettling is involved (I'm only pointing him in the basic direction of his starting
point as I freely admit that zetec's aint my bag baby )
G
BKLOCO
posted on 1/3/06 at 10:25 AM |
If you're not in any great hurry then there is a possibility that I may have a modded Zetec sump going spare shortly.
(Just got to get round to doing it)
They are not that difficult to weld and seal
It’s all a matter of preparation.
It's not the material that’s the problem, it's the cruddy deposits from the oil that if you don't clean off 100% then it
"gasses" whilst welding and cause the weld to become porous.
emsfactory
posted on 1/3/06 at 10:41 AM |
Are the sumps steel?
Surrey Dave
posted on 1/3/06 at 11:40 AM |
Only fettling I did was ,a few taps with a ball peen hammer to get more clearance in the area where the oil pipe bolts on, also drilled and tap more
holes , with the block upturned , did not take long, yes they are steel so you can easily modify the depth/shape to suit.
Will post picture later...........
[Edited on 1/3/06 by Surrey Dave]
Surrey Dave
posted on 1/3/06 at 04:39 PM |
Block Holes
Surrey Dave
posted on 1/3/06 at 04:41 PM |
Sump On.........
Just got to shorten it now.........
austin man
posted on 1/3/06 at 10:52 PM |
sump mods
I take it that several of the holes already line up ??
there are some raised indentationd do these require flatening out ??
ps thanks for all responses
donut
posted on 2/3/06 at 09:40 AM |
Most of the holes do line up.
Dave: you taking orders for sump chopping yet?
Surrey Dave
posted on 2/3/06 at 02:24 PM |
I can't even be bothered to go out in the shed and do my own!!!!!
Its been too cold and dark for old people like me!!!!!
