Author: Subject: Master cylinder
martin_406
posted on 14/3/06 at 09:08 PM Reply With Quote
Master cylinder
Hi
I´m about to build a pedalbox for my seven but I do have some problems with the choise of brake master cylinder. Front brakes is a Wilwood powerlite kit from gts and in the rear there is disc brakes from Alfa Romeo 105series. I will not use a brakeservo. Which donor car has a master cylinder that would suit this combination of brakes?
Thanks/Martin
RazMan
posted on 14/3/06 at 09:15 PM Reply With Quote
Hi Martin, welcome
If you are building a pedal box why not go for a pair of new Girling m/c with a bias bar - not expensive and you will have the knowledge that they are new and unlikely to fail.
[Edited on 14-3-06 by RazMan]
Raz
posted on 15/3/06 at 10:38 AM Reply With Quote
With that combination you really would be better with a dual pedal box -- the cost do add up by the time you add the resevoirs with level switches.
All the usual suspects sell kits but as you bought the front brakes from GTS why not continue.
martin_406
posted on 15/3/06 at 06:23 PM Reply With Quote
It looks like it will be a dual pedal box. thanks for the replies/Martin
