Krismc
posted on 9/4/06 at 01:21 PM |
SIERRA REAR BRAKE DISCS
Got a rear beam from a XR4 (i think) with a 3.62 LSD!
Which pads and discs do i require?
(or whats the biggest i can fit)
mookaloid
posted on 9/4/06 at 01:22 PM |
Well the XR4 had drums and an open diff so it's not off that
RichieC
posted on 9/4/06 at 01:35 PM |
Im sure you mean XR4x4, which used the standard (all Sierras except Cosworth used the same size) 253mm rear disc.
Rgds
Richie
mookaloid
posted on 9/4/06 at 01:39 PM |
The 4x4 ghia had solid discs and i think the xr4x4 had vented discs so the calipers are also different - worth checking to see which ones you have.
Mark
Mr G
posted on 9/4/06 at 02:04 PM |
No xr's or standard sierra's were fitted with vented rears.
Only the cosworth 4x4 (sierra/escort) and granny cosworth had 273mm vented rears (granny being 5 stud remember)
First step is to establish what you've got - xr4i (2.8) xr4i (2.0) xr4x4 2.0/2.8/2.9
G
[Edited on 9/4/06 by Mr G]
mookaloid
posted on 9/4/06 at 02:22 PM |
Ah right I wasn't sure
posted on 9/4/06 at 03:16 PM |
Why do you want bigger heavier brakes? You don't need them.
dave1888
posted on 9/4/06 at 04:45 PM |
All rear disc sierras have the same caliper except the RS Cosworth 4x4 which has a 273x20mm vented disc the rest have a 253x10mm solid disc. info from
speedways website.
http://www.speedways.co.uk/shop/index.html
Krismc
posted on 9/4/06 at 04:53 PM |
yea def only 2 types off callipers when i ordered from brake int, they only had 2 types!
so its the solid ones then for me !
cheers thats cleared that up! standard pads be ok i suppose?!
Krismc
posted on 9/4/06 at 05:01 PM |
www.speedways.co.uk
253 x 10 discs = £23, pads £26
total 4 pads and 2 disc's + £72 delivered with vat
sounds good too me
Mr G
posted on 9/4/06 at 07:25 PM |
quote: Originally posted by Krismc
www.speedways.co.uk
sounds good too me
Does it??
How about £35.92 Delivered from www.buypartsby.co.uk
Discs will be DelphiLockheed too. Logo for the pads is showing as mintex.
DISCS/PADS INFO
HTH
G
Krismc
posted on 9/4/06 at 08:59 PM |
SPOTTY DOG...even better
