Slater
| posted on 26/5/06 at 10:30 AM |
2 Donor diff questions
Here is my freshly removed diff.
  donor diff with bracket
Questions....
1) I presume I dont need that bracket (top right of pic), how do you remove it? It has 2 bolts at the back, but no room to get any socket to the lower
bolt head?
Heres a pic of the 2 bolts holding the bracket on.
  donor diff bracket
2) What the best way to clean it, without getting dirt/water inside? I've got a couple of carrier bags stuffed in the holes.
I've got loads of other questions about my other donor parts, but will post them later, don't want to swamp anybody!!
Keith.
scoop
| posted on 26/5/06 at 10:36 AM |
You dont need the bracket and you are gonna need either a long socket or extention arm but those bolts are the only way off. I just put a couple of
rubber gloves over the drive shaft holes and got to work with the degreaser and a stiff brush (toothbrush probably). It looks like you gonna have to
clean the driveshaft holes as well though
andyace
| posted on 26/5/06 at 11:13 AM |
I too just blocked up driveshaft holes with some latex gloves. I used white spirits and a brush to get the greasy stuff off and the a drill mounted
wire brush to clean off the dry crap. Once clean a quick paint with smoothrite and it looks gr8.
Slater
| posted on 26/5/06 at 01:16 PM |
Using latex gloves to block the holes is a good idea. Or I could just push the drive shafts back in, then get to work with a brush and gunk. Thanks.
ProjectX
| posted on 26/5/06 at 03:40 PM |
Dont forget, Mr Muscle oven cleaner. Fantastic on ally bits. Heres mine after the muscle treatment and drill mounted brush.
Project X
