AndyGB
posted on 11/6/06 at 08:30 PM |
XR4I Any Good
Would a XR4I be ok on a Y plate for a doner car for a bike MK INDY they do have LSD dont they and rear disc brakes i can get it for cheap so need to
know before it goes
BKLOCO
posted on 11/6/06 at 08:36 PM |
know before it goes
It's FWD
gary gsx
posted on 11/6/06 at 08:38 PM |
Xr4i has drum rear brakes and no lsd if it was a 4x4 then it would
AndyGB
posted on 11/6/06 at 08:39 PM |
no its rear wheel drive v6
big_wasa
posted on 11/6/06 at 08:57 PM |
Defo drums on the back, mine had an lsd but every one seems to say they dont ? If the one you are looking at doesnt then I cant see any advantage over
a newer donor
gary gsx
posted on 11/6/06 at 09:00 PM |
Mine didnt have an lsd but great fun as it was
BKLOCO
posted on 11/6/06 at 09:07 PM |
Sorry had a beer or three miss read it as Xr3
oops!
mookaloid
posted on 11/6/06 at 09:27 PM |
Xr4i has unusually large 10" rear drums which means that the handbrake cable fouls the Indy rear upright mounting bolt.
They do have a close ratio gearbox which is good if you are going for a pinto or zetec etc
They also have larger front brakes which could be a good thing
No LSD either
not a great start for a BEC Indy though
Mark
AndyGB
posted on 11/6/06 at 10:21 PM |
Thanks for the comments guys will keep looking for a 4x4 but they seem to be going up in price of late
posted on 12/6/06 at 12:06 PM |
The 4x4 is only good for the diff. If you're not too bothered about LSD, there are alternatives available which may have more donor parts
available to use, as well as better ratio diffs (depending on which bike engine you want to use)
Phil
