theohighland
posted on 25/7/06 at 07:11 PM |
rear drums and front calipers???
would anyone be able to tell me what other (hopefully cheaper and more readily available) rear drums i could get for an escort axle, and what, if any,
other types of calipers fit front cortina hubs
cheers, theo
theohighland
| posted on 25/7/06 at 07:26 PM |
also.... does anyone know of a smaller sized (and therefore probs power) altenator as im using a dohc engine and at the mo the altenator wont let me
fit the engine in the chassis!
Michael
| posted on 25/7/06 at 08:09 PM |
Not sure about brakes, but from experience Japanese Motors have small alternators.
smdl
| posted on 25/7/06 at 08:22 PM |
Most of the Birkin folks over here use Suzuki alternators.
HTH
Shaun
mark chandler
| posted on 25/7/06 at 09:17 PM |
no electric windows, heated rear screen aircon fans etc, fit the smallest one you can find... so basic car such as a micra and see whats under the
bonnet.
As long as it can keep up with the lights and small engine draw you are fine.
Regards Mark
robinj66
| posted on 25/7/06 at 09:18 PM |
Princess 4 pot calipers will fit Cortina hubs.
Not sure whichother Frds were fitted with M16 calipers but you could try Mk II Granada and Mk II Capri as starters
smdl
| posted on 25/7/06 at 10:41 PM |
Of course, there are also several aftermarket calipers available to replace the M16s, such as Wilwood, Raceleda, etc. These are definitely not
cheaper, though!
Shaun
PaulBuz
| posted on 26/7/06 at 06:07 PM |
I think you will struggle with any alterator to get clearance for the steering coloum.
I'm using the same engine.
Heres my solution.
Paul
| posted on 28/7/06 at 08:10 PM |
I fitted GIANT 3" wide drums from a 2.8i Capri to my Striker with standard 13" wheels. They filled the space nicely and the braking
performance was superb. They pull the back down nicely when you chuck the anchor out.
Bought all the bits brand new from GMS and my local Ford dealership. (a few years ago now mind, but this century)
