auzziejim
| posted on 11/5/03 at 08:22 AM |
2nd Donor!
advise needed here guys, i need a couple of parts (Caliper, Driveshaft and hub carrier) and the only scrappy in a 25mile raduis wants £60 for these
items (i duly told them to fu<k off) but i have the chance for a second sierra donor. This is £25 and is complete and running.
The problem is i only have a month or so to wait for my kit and i want the garage clear for when it arrives and also this new siera has rear disk
brakes so i will need the whole diff, shafts and brake set up.
So what i want to know is, is this a good idea or do i source the parts seperatly? Are there any probs in using disk rears on the indy?
bob
| posted on 11/5/03 at 08:48 AM |
JIM
I've got discs on mine and a few others have done it,the hub carriers have to be drilled in a different possition so best tell martin if you are
going this route.
Too cure overbreaking at the rear i have fitted a FIAT uno reduction valve (cheap as chips),which i will set at SVA.
The only problem i've had is bleeding the rear calipers as they cant sit on top of the disc as on sierra/granada's,they sit to the back at
about 10 o-clock so creating an airlock.
It just means you have to remove the caliper to bleed,then again you should only need to do this once or until fluid change.
Also 14" plus wheels are needed to fit over calipers.
Hope this helps
[Edited on 11/5/03 by bob]
Viper
| posted on 11/5/03 at 09:31 AM |
Hope this helps
Bob
thats not strictly true, i noticed at the show that MK put the calipers on upside down, you could put them the other way up(as i have) and have the
bleed nipples at the top as ford intended, only thing then is the handbrake cable comes out the bottom..
Tim
bob
| posted on 11/5/03 at 01:40 PM |
TIM
I tried them upside down 1st but as you say the handbrake cable loops round underneath,its a bit neater the way i've gone and i think i can live
with the air lock bit.
auzziejim
| posted on 11/5/03 at 03:02 PM |
bob is it worth the hassle of getting the second donor and degreasing and painting all of the rear subframe when all i need for drum brakes is a
shaft?? it will be cheaper i know but if i can sell other parts im gona do it!
(as you can tell im talking sh!te due to a heavy afternoon in the pub!!!)
James
bob
| posted on 11/5/03 at 06:31 PM |
Its worth the hassle Jim,they do look nice with rear discs and stop on a sixpence too.
I'm 42 this year so its still still sixpence to me
ChrisW
| posted on 12/5/03 at 08:37 AM |
Well worth it I'd say. I've just stripped my third donor and I've been looking at numbers four and five
Not all the bits have gone on my Locost I must point out!
Chris
My gaff my rules
auzziejim
| posted on 12/5/03 at 04:57 PM |
well chris im very pleased that not all of those parts are being used on your car as that would be one very wierd car
So i will talk to my friend with this sierra tonite and will hopefully strike a deal
Cheers for all the advice guys
cheers
James
auzziejim
| posted on 13/5/03 at 06:41 AM |
a deal was struck last night and i pick up my new 2.0i DOHC donor on saturday for the princely price of 2 pints! result!
So anybody need any Sierra donor parts?
James
