Author: Subject: Rusty Nut!
StevieB
posted on 5/9/06 at 09:21 PM Reply With Quote
Rusty Nut!
Does anyone have any advice on the best way to remove rusty track rod ends - I've tried every methind possibly, including the old 'pu it in a vice and t**t it' method. I've also been spraying WD40 on them to hopefully loosen things up - no joy
Would heating them up help?
Danozeman
posted on 5/9/06 at 09:23 PM Reply With Quote
Heat then up if u can. Have u put in on something hard and hit it all the way round? This often frees them up.
Dan
StevieB
posted on 5/9/06 at 09:26 PM Reply With Quote
I'll try bashing them about tomorrow then - and if not, I've got an excuse to buy a blow torch at the weekend!
russbost
posted on 5/9/06 at 09:40 PM Reply With Quote
Take a grinder to it - That Works!
posted on 5/9/06 at 09:55 PM Reply With Quote
Buy some new track rod ends?? They'll probably cost you less than a blow torch
Phil
StevieB
posted on 5/9/06 at 09:56 PM Reply With Quote
That's my last resort option - using my dremel cut off disc to carefully cut the nut and TRE off.
Is there anywhere that sells aftermarket steering rods (reasonably priced) - the best option would be some nice shiney new items with nice shiney new TRE's.
MikeR
posted on 5/9/06 at 10:56 PM Reply With Quote
forget WD40, use "plus gas", fantastic stuff, you can usually get it from Halfords as well
DaveFJ
posted on 6/9/06 at 07:53 AM Reply With Quote
I have always found a blob of weld from my mig welder does wonders at warming up/loosening nuts.....
Dave
indykid
posted on 6/9/06 at 05:09 PM Reply With Quote
not in dewsbury you can't. halfords don't stock it anymore, just to save you a trip.
if they have dixon hall in york, they do it. about £5.50 a big tin
tom
StevieB
posted on 6/9/06 at 07:25 PM Reply With Quote
To be honest, I try and avoid Halfrauds at all costs - I'd rather find a local trader and keep them in business!
Does anyone know if you can gget brand new aftermarket streering track rods (the rods themselves, not just the ball joints) - if they're not too expensive, I'd rather have the shiney new option any day!
posted on 7/9/06 at 05:04 PM Reply With Quote
Electrolysis. See the light!
This is the single best thing I've ever found out! (quote!)
This is the way, try it, you wont look back.
http://locostbuilders.co.uk/viewthread.php?tid=9158
StevieB
posted on 7/9/06 at 05:31 PM Reply With Quote
I've read about this a few times and am tempted to give it a go. I suppose the question is whether this method will unstick seized nuts/TRE's. If so, I'll give it a whirl
posted on 7/9/06 at 06:56 PM Reply With Quote
You have unlocked the lock nut haven't you? I've never had a lot of trouble with track rods even though they look dog rough. There's a flat on the track rod end so you can get a spanner or Mole grip on it while you back the lock nut off a couple of flats. It's cheaper and easier to get a recon rack than trying to find parts for an old one. Mine was about £20 exchange for a Mk2 Escort rack.
StevieB
posted on 7/9/06 at 07:36 PM Reply With Quote
That's the problem - I can't seem to get the locking nut turned back. I've been trying all week and soaking in WD40 every time in a hope it'll penetrate the rust and loosen things up.
I guess just perserverence while getting on with other things will eventually work
DEAN C.
posted on 10/9/06 at 05:55 PM Reply With Quote
Hi Stevie,I'm not sure what you are trying to save,seeing as a new sierra steering rack is about £25 fully reconned with new track rods,and you need to buy a pair of new TRE's anyway.
I bought my rack about four years ago for £18 from local discount shop at Trade price admittedly.
If you get daft prices i'll price them up around Donny at Trade for you.
Dean.
[Edited on 10/9/06 by DEAN C.]
Once I've finished a project why do I start another?
StevieB
posted on 13/9/06 at 02:40 PM Reply With Quote
Might have to be an option.
All I'm trying to do is get the old TRE's off the extentions so I can put the new one's on. I've now done everything possible and getting no-where!
Sod it - £12+VAT for new rods, that'll do and to hell with the messing around!
[Edited on 13/9/06 by StevieB]
