Author: Subject: Sierra Master Cylinder Resevoir
StevieB
posted on 4/10/06 at 07:18 PM Reply With Quote
Probably been asked before but:
When you mount the sierra M/C, the M/C is parallel to the ground and the resevoir is canted back - does this end up being a problem?
If so, is there an after market item that would fit (I've seen some, but they seem to have angled spouts on them, which would end up in the same scenario).
Sorry if it's been done to death before
flak monkey
posted on 4/10/06 at 07:21 PM Reply With Quote
They are all like that, and its not an issue as far as i am aware
Sera
http://www.motosera.com
mackei23b
posted on 4/10/06 at 07:34 PM Reply With Quote
Hi there
Mines parallel to the ground.
Ian
StevieB
posted on 4/10/06 at 07:46 PM Reply With Quote
How've you managed that - an after marker resevoir?
posted on 4/10/06 at 07:57 PM Reply With Quote
If it was a problem you would not be able to drive uphill The fluid level is all that matters. I put the brackets on my car so the fluid line is level when the car is parked level
Top mount pedals.
Top mount pedals.
[Edited on 4/10/06 by Peteff]
StevieB
posted on 4/10/06 at 08:07 PM Reply With Quote
Top mount pedals.
Top mount pedals.
That's quite a mechanism!
I don't have that luxury as I'm building an Indy, which has everything pre-drilled, though maybe a block of ali shaped to a wedge like form could work.
Probably not worth the effort though?
pajsh
posted on 4/10/06 at 08:59 PM Reply With Quote
Dittto my reservoir is level and m/c is canted.
Master Cylinder
Master Cylinder
I have changed the master cylinder from a sierra servo assit one to a none servo Eccy Mk II but kept the Sierra reservoir as the eccy one was flat. Holes matched up perfectly.
So if you want a flat one hunt down a Mk II Eccy. You might need the Sierra top though as the Eccy one did not have a level switch in it.
[Edited on 4/10/06 by pajsh]
I used to be apathetic but now I just don't care.
StevieB
posted on 4/10/06 at 09:25 PM Reply With Quote
The sierra item is very similar, apart from the front brake pipes comes from the end of the M/C rather than the side.
I'd been starting to de-grease the old M/C and was about to buy a new piston/seal kit when I found a new sierra one on Ebay for £18 - job done!
posted on 4/10/06 at 09:43 PM Reply With Quote
Our M/C is level and the reservoir is at an angle. It's not a problem and it rarely needs to be topped up. If you're not happy though, you can always mount the reservoir remotely but just think of all that extra weight with the rubber pipes
Phil
StevieB
posted on 4/10/06 at 09:47 PM Reply With Quote
That's my philosophy on everything to do with my car - if it's not the simplest solution, it's just too much weight!
I'll just give the resy a good soak in degreaser for a few days (really sludged up inside) and then use that.
posted on 4/10/06 at 10:34 PM Reply With Quote
Don't put anything in it but brake fluid, the seals don't resist much else especially petrochemical based stuff, it turns them to mush.
StevieB
posted on 5/10/06 at 07:26 AM Reply With Quote
Really?
Oh, erm....
Oops - too late!
