Author: Subject: What do I keep from my Sierra?
hillbillyracer
posted on 25/11/06 at 09:50 AM Reply With Quote
I suppose the title says it all really.
It's a GLS 2l twincam carb engine & MT75 box. I was going to leave this till nearer the build but I want a tidy up.
I'm keeping the engine, drivetrain, suspension, steering (inc column & switches) & pedal box.
Are there any other less bits obvious bits I should keep? I'd like to put the ID on the Locost too (H reg), anything important I should do regarding that?
stevec
posted on 25/11/06 at 10:35 AM Reply With Quote
Hand brake lever and cover. Brake M cly. Relays and fuses.
Steve.
[Edited on 25/11/06 by stevec]
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 25/11/06 at 10:37 AM Reply With Quote
keep everything as long as you can! if you have the space strip the lot and keep everything, you never know what might come in handy, thats what i found!
marshall
posted on 25/11/06 at 11:03 AM Reply With Quote
ECU unit is a must and as many bolts and washers as poss plus seat belt bolts..
Humbug
posted on 25/11/06 at 11:43 AM Reply With Quote
If by ID you mean registration number, then get it transferred to a retention certificate before you scrap it. Otherwise you won't eb able to keep the same number, only (at best) get an age-related number, i.e. another H reg - always assuming you have enough other points.
Kook
posted on 26/11/06 at 05:08 PM Reply With Quote
You can only put a Number plate on retention if the car is Mot'ed and taxed...
If you are just after a age related plate keep the v5 form and keep it sorned ... You will then get a H reg plate on ya car if u use 2 items from doner
