86barettaguy
posted on 29/6/03 at 07:51 PM |
Ford Orion
Kinda planning what to do with my ford orion once we get a new car to replace it. I've been thinking that I need a car that is fun to drive
instead of just a vehicle for transportation. Anyway, I figured I might as well find out what parts from the orion could be used in a locost and what
modifications would be needed to the chassis.
also, how do you translate that "16 gauge" measure? metric system anyone?
Mark Allanson
| posted on 29/6/03 at 08:03 PM |
You could use the engine, coupled to a suitable box, the steering column, wiring loom, possibly the wheels
16g =1.6mm
ChrisW
| posted on 30/6/03 at 07:34 AM |
Seconded. You could use either an Escort mk2 box (4 speed) or a Sierra type 9 (5 speed). Column will fit but you'd have to make your own
downlink. You'd also need the Escort mk2 steering rack, back axle and Sierra or Cortina hubs. Loom and wheels are certainly usable though.
Chris
My gaff my rules
86barettaguy
| posted on 30/6/03 at 08:16 AM |
so the engine would fit right in? that has actually been one of my main questions when thinking about building a locost (been thinking about it for
quite a while): what if the engine compartment turns out to be too small.
Are ford gearboxes totally interchangable? or would modifications be needed (I definitely think I'd go with a sierra gearbox as the early
escorts are rare around here)?
stephen_gusterson
| posted on 30/6/03 at 10:25 AM |
It wont fit right in.
An orion is FWD.
Once you have gone to the trouble of getting another box and mating it up with the correct clutch, you would probably be better getting a sierra 2
litre. Its gonna have a bigger more powerful engine than your orion, and will also have the support of other companies such as MK engineering, who can
supply adapters for the hubs, and likely sell you suspension parts.
I recon you would be taking a harder route and be fairly on your own using orion / escort parts.........
atb
steve
[Edited on 30/6/03 by stephen_gusterson]
Stu16v
| posted on 30/6/03 at 07:20 PM |
Stephen is spot on. The CVH *can* be fitted, but is the pissing about worth it? IMO no. Westfield offer them (or used to anyway) as an engine option,
and they are quite tunable, so the parts are out there, but you have a lot of engineering as regards engine mounts (no dedicated lugs on block for
north/south mounting), resiteing of alternator etc. Dropping on S/H inlet and exhaust manifolds will be difficult too, compared to other Ford
stuff.
Otherwise, build a mid-engined car, and utilise your gearbox too....
Stu.
86barettaguy
| posted on 1/7/03 at 07:18 AM |
Stu.
I started thinking about that yesterday (yes, really, I did). But I think I'd have to do some slight modifications to the gearbox unless I want
5 reverse gears, right? anyone know where you could find info on converting front-engine/FWD to mid-engine/RWD?
I'm guessing the chassis won't be too hard to re-design...
So are there any engines (from RWD cars) that won't fit the locost unless you modify the chassis?
ChrisW
| posted on 1/7/03 at 11:01 AM |
Have to disagree on the fact that it would be harder to do. The CVH is very capable (my XR2 has been on the rollers at 158bhp at the wheels naturally
aspirated) and will mate straight up to a type 9 5 speed box or an older Escort mk2 4 speed box. It will all go into a standard chassis and will be
far lighter an shorter than a Pinto with the same power capability.
If you do decide you need more power there are plenty of tuning bits out there for it (cams, heads etc) or you could very easily swap it out for a
turbo unit.
Chris
My gaff my rules
ned
| posted on 1/7/03 at 11:06 AM |
what have you done to the xr2 to make it 158bhp, that sounds like money has been thrown at it, they're not that high as standard surely?
Ned.
beware, I've got yellow skin
stephen_gusterson
| posted on 1/7/03 at 01:26 PM |
building a locost is a time consuming excercise.
Do it a different way and you will spend alf your life on it.
Buy a sierra.
You will remember my words sometime in 2007 and know only too late I am right.
I speak from experience.
atb
steve
Simon
| posted on 1/7/03 at 01:49 PM |
".......some slight modifications to the gearbox unless I want 5 reverse gears, right?"
Why?
If the engine is mid-mounted in the same configuration as it came from the donor then you'll still have 5 forward gears, unless you insist on
turning the engine around by 180 degrees.
Your problems will be gear linkage, uprights and wishbones, unless you use all major components from donor building chassis around them, and using
some kind of tie rod to stop your rear wheels from steering.
Simon
escary
| posted on 1/7/03 at 07:18 PM |
aren't we all builders
be encourged to experiment, cvh engines are very tunable.
it does take time but then what that matters doesn't?
my build is book/racing and is so that i can get an age related plate, once i'm through sva the xflow will go in favour of something more modern
and with greater power. (sorry xf guys)
my current car is a fiesta rs turbo which has had about a further 500 pounds thrown at it from standard.
Magnex exhaust, 195 chip, induction kit and hybrid t2 turbo. It makes 195bhp at the flywheel (as per dyno run printout and 155 at the wheels)
if the fiesta is scrap by the time the lowcost is complete guess where the engine is going.
xr3i's aren't too bad with 110bhp standard and there is a host of go faster parts, this together with that the mechanical injection set up
doesn't seem too hard to fit , less electrics, spend about £200 on a cam and expect a further 20bhp at the flywheel.
so wether it's rear wheel drive through a type 9 or a mid engine go for it.
yes it will take longer but if you can build a car then it is just another task to overcome.
alternately build a mcsorley plus 4 wider car so that chassis width isn't an issue.
if you can make a car you can make engine mounts.
realise the dream
but
you may well find that basing a build on an orion just because tou have it may prove more expensive that a more classic build.
the most important thing is that you please you.
i'm off for the flack jacket and await opinions
Regards
Ewan
Stu16v
| posted on 1/7/03 at 07:50 PM |
aspirated)
That is a LOT of power from a CVH. And to get that kind of power I guess you have thrown a lot of money at it, considering a 16v Vauxhall xe motor is
only 180 at the flywheel on twin 45's....
The CVH *may* have the same power capability as the Pinto (mmmmm...) but there are far fewer comanys tinkering with them, and far fewer tuning goodies
on the S/H market. To me, that in itself says it all....
stephen_gusterson
| posted on 1/7/03 at 09:17 PM |
escary - no flack from me but, as you say
its a bit daft modifying a whole build just cos you happen to have a particular car.
As it costs 50 quid around here to get a sierra taken away, then an ad in a paper will get a sierra for free.
Then you would have the right car just hanging around.
ANYONE on this list used a FWD escort car as a donor?
atb
steve
Stu16v
| posted on 1/7/03 at 09:43 PM |
I used a FWD Astra as a donor....but only for the engine!
stephen_gusterson
| posted on 1/7/03 at 09:56 PM |
aquward bugger!
Im just tying to make a point that its not worth the struggle to use a 75 - 90 hp 1.4 - 1.6 cvh from an orion and save this guy a whole loada
grief.
If its summat like 150hp from an astra 2 litre, its possibly worth the hassle!
atb
steve
[Edited on 1/7/03 by stephen_gusterson]
86barettaguy
| posted on 1/7/03 at 10:39 PM |
quote: Originally posted by stephen_gusterson
aquward bugger!
grief.
atb
steve
You might be correct. Or maybe not. The engine is powerful enough for me, that's not a problem really. I'm not going for a racer
anyway.
This thread was basically just a way of finding out what options I have with my orion.
Unless I'm going mid-engine (sorry for my apparent lack of knowledge about gearboxes and how everything's hooked up btw ) I think
I'm discarding the Orion as a project. It needs too much work to be more than just a vehicle for transportation better brakes, stiffer
chassis, re-located engine... I'm probably better off trying to sell it...
btw, I don't think that a mid-engined car is necessarily harder to make than a front engined car. It's different but it's only the
location of the engine bay and the linkage for the gearbox... and the rear suspension. from what I've seen in magazines, the engine bay is
basically just a box and then the rest is built around that.
stephen_gusterson
| posted on 1/7/03 at 11:29 PM |
quote
unquote
Thats extremely simplistic.
Just take a look at the subject of suspension.....there are loads of parameters involved in getting a well handling car. Things like bump steer,
ackerman, scrub radius, toe in, camber, roll centres, I could go on.
'the book' locost is kinda proven, andything you may decide to do yourself isnt.
Just consider the following for a rwd mid engined using front engined bits :
1. handbrake - how? The front wheels on the back dont have one.
2. gear change - how? the gear mechanism will be at the rear number plate - you need the hassle of your own linkage design.
3. your front engine has steering - you need to get rid of it and that will likely induce bump steer due to the tie rods you use to anchour it.
Its quite easy to end up with a car worse than the book, as a car isnt just a box with wheels in the corner. 100 years of automotive industry have got
good handling to the state it is.
Us builders that go out on their own have very little knowledge of that 100 years - and there is so much scope for error.
the closer you stick to a proven design, the less likely mistakes will be made. The more you deviate from the book, the more time the build takes.
Jasper build a 'book' bike engined car in a year. Im building summat different and im in year four.
As mr gibbs once said 'does all the extra time add to the driving experience'. Probabably not,
My 'weird' build is cos I wanted summat different from a seven replica. If you want a seven replica, follow the accepted examples of 100s
of cars that came before yours.
making a rear engined car will add lots of time and hassle to the project - and what will you gain?
Building a car and making mods to it isnt as simple as you think.
trust me as one who has strayed from the path.
atb
steve
86barettaguy
| posted on 2/7/03 at 09:00 AM |
atb
steve
of course, suspension is a science. And with a mid engine it's the gear change mechanism that puzzles me. It's not like I'm planning
to start building without first having something to go by. that would be plain stupid unless you really know what you're doing (even if it is a
proven design like the locost)
Let's assume now that I'll either stick with the locost design or just modify the existing car (and let's just assume that I will
either keep the orion or get something different). We don't have to discuss the problems of the mid-engined designs right now (we don't
even know which way I'm leaning yet).
and as to the reasons for thinking about using a FWD escort/orion as a donor... It may be better to use a RWD Sierra. Or a RWD escort (I never see
those around here though). But if everyone used the same cars as donors, we would never find out if anything else worked. And we would all end up with
very similar cars. Half of the fun is in planning and finding out what works and what doesn't, isn't it?
stephen_gusterson
| posted on 2/7/03 at 10:36 AM |
yes, its nice to do something different.
I have done lots of things differently.
Just little things really add to the time!
If you want a rear engined car, how about using mk1 mr2 bits - the engine is powerful, and people - like alan B's meerkat - have done it
before.
atb
steve
kingr
| posted on 2/7/03 at 11:27 AM |
My opinion would be do what you really want to do, if you want a middy, great, go for it, what does it matter if it takes longer than it might if
you're enjoying what you're doing? If on the other hand you want to use the onion because you've got it and it's convenient, I
wouldn't bother, flog it off, and buy a cheap, crap sierra, hell if you're that fond of the CVH, get one with one of them in it, and
it'll already be set up for RWD. I think the primary reason the CVH isn't used very much is because while it's OK, it's not
great at anything in particular, it's not nice, new and shiny with 16 valves like the zetec/duratec, it's not mind numbingly simple or
have tuning parts coming out of it's ears to the extent of the xflow or to a lesser extent pinto, it hasn't got the raw grunt and sound of
a V8 or the shear screaming instanity of a bike engine, but it's still and OK engine, and in many ways better than a pinto if it were only made
in a 2 litre capacity.
Kingr
ned
| posted on 2/7/03 at 11:37 AM |
why not take a look at the mid engined section? alanb and the like are very knowledgable and I'm sure will be more than happy to help if you do
decide to go down that road...
use whatever engine you like, there are pros and cons of each. just consider the ffort of the various options and when you're happy, "just
do it " (no nike copyright infringment meant)
Ned.
86barettaguy
| posted on 3/7/03 at 11:28 PM |
yep. this wasn't intended to be a mid-engine vs front-engine vs whatever discussion anyway. My initial questions have been answered
thanks for the help btw
