Author: Subject: camaro
dilley
posted on 4/3/07 at 04:43 PM Reply With Quote
camaro
does anyone know anything about a Camaro z28 engine?
5.0L (305)??
is it a v8?
flak monkey
posted on 4/3/07 at 04:49 PM Reply With Quote
Yes, its a V8. The baby V8 of the range. They also did a 5.7l V8 and a 3.8l V6.
Sera
http://www.motosera.com
speedyxjs
posted on 4/3/07 at 04:50 PM Reply With Quote
Should be nice in a locost!
stevec
posted on 4/3/07 at 04:52 PM Reply With Quote
It is a V8.
Alittle like this,
dilley
posted on 4/3/07 at 04:56 PM Reply With Quote
Any idea on power, and what box will it fit??
I can have the whole car for next to nothing, its also running injection and its an 83 model.
it has just had a performance 700r4 transmission(auto) and a 2000 stall torque converter, also has a rebuilt rear axle.
flak monkey
posted on 4/3/07 at 05:03 PM Reply With Quote
It depends on the model of the engine, there were several floating around at the time. But it should be an L69 engine in that if its an '83. so will be about 190bhp ish, and around 250 lb.ft torque.
Sera
Dale
Cant say for sure but an 83 should have under 200hp and a t5 would have been an option for it.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
Mark Allanson
posted on 4/3/07 at 06:10 PM Reply With Quote
our receptionist at work has one in his montecarlo, 110bhp, 3:1 compression ratio, revs to nearly 4000rpm when warm (it never is!). I does 0-60 in a weekend and the speedo only goes to 80mph
[Edited on 6/3/07 by Mark Allanson]
flak monkey
posted on 4/3/07 at 06:15 PM Reply With Quote
The 307 had a low compression ratio eco version which was 115bhp (one a good day) and was terribly unreliable. It was dumped in 1983 for the 305 small block which has the specs as i mentioned above.
Sera
chrisg
posted on 4/3/07 at 06:26 PM Reply With Quote
I used to own one like this
But much, much rustier
Chris
dilley
posted on 4/3/07 at 06:52 PM Reply With Quote
not such a good engine then how does it compare to a RV8?
Pezza
posted on 4/3/07 at 09:13 PM Reply With Quote
mmmm gen 2
Almost bought one in black a couple of years ago, had a hoooge supercharger and ram scoop on the bonnet *drools*
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
