selig R1
posted on 4/3/07 at 10:14 PM |
ZETEC FLYWHEELS
Your the first person to have done that thank god some one has!! did you use the trigger marks on the flywheel for the EUC or did you put a
trigger wheel on the front of your engine.
Allan
theconrodkid
posted on 5/3/07 at 06:00 AM |
just use marks on flywheel,its the same as 2.0 just about 1/2 the weight
who cares who wins
pass the pork pies
mad4x4
posted on 5/3/07 at 10:23 AM |
watch the position of the trigger, Make sure if using the manual flywheel you have the bracket for the tigger from the a maunal engine. as they are
different positions
If I remember correctly the manual trigger sits closer to the block the auto sits very close to the ringgear.
Scot's do it better in Kilts.
selig R1
posted on 5/3/07 at 08:32 PM |
Thanks conrodkid, I can now start looking at other reasons why this engine will not run.
stevebubs
posted on 5/3/07 at 10:40 PM |
quote: Originally posted by Scoobylav
Just dont get a dunnell lightened one as the "teeth" on it arent good enough to trigger the sensor properly .. . . . . . in my experience.
Worked fine for me...crank sensor is sensitive to the polarity of the wires, though...
