Author: Subject: sierra estate
steve4179
posted on 30/4/07 at 07:10 PM Reply With Quote
sierra estate
can a sierra estate be used for a donor for the haynes roadster, im guessing the only difference between that and tha hatch or saloon is the prop shaft?
cheers steve
flak monkey
posted on 30/4/07 at 07:11 PM Reply With Quote
Identical other than the arse end of the body.
All the running gear is the same.
Sera
http://www.motosera.com
steve4179
posted on 30/4/07 at 07:41 PM Reply With Quote
cool cheers mate
Schrodinger
posted on 8/5/07 at 06:29 AM Reply With Quote
There is a difference in the rear beam/semi trailing arms but as you wont be using these there shouldn't be a problem
