Bluemoon
| posted on 13/8/07 at 10:54 AM |
Sierra Master cylinder
Hi all,
Some one must know the answer to this one, of the 4 different Sierra master cylinders, two are Bendix items. Of these two are the fluid reservoirs
interchangable?
(I can only obtain a replacement for my Bendix cylinder that is the type with the end outlet pipe at right angles to the body, not straight out and up
as my current part)
Dan
Bluemoon
| posted on 17/8/07 at 01:49 PM |
BTT,
Maybe someone could measure the distance between the pipes on the reservior? And the diameter of the pipes if possible?? on the Bendix cylinder with
the end pipe pointing to one side?
Dan
40inches
| posted on 18/8/07 at 04:19 PM |
You can get both types here http://www.brakeparts.co.uk/ looks like the right angle ones come complete with reservoir for around £35,follow the links
for>Ford>Sierra>2.0 OHC
Bluemoon
| posted on 22/8/07 at 12:38 PM |
Right both 85mm spacing, ordered a replacement so fingers crossed.
afj
| posted on 24/8/07 at 04:54 PM |
sorry to hijack this thread but i got a freebie girling steel tube master cylinder today from work from a 1.6 f reg sierra is this any good for
a front and rear disc setup in a indy
