tegwin
| posted on 18/9/07 at 04:51 PM |
Specification of sierra Donor
I spotted an interesting Donor...
But does anyone know what the spec of it is?
What gearbox is it likley to be? And is the diff going to be LSD?
Its a sierra 2.0L GLX estate on an H reg...It has the 2.0L DOHC engine....
(Oh, and is the engine and tranny aluminium or steel?)
[Edited on 18/9/07 by tegwin]
stuart_g
| posted on 18/9/07 at 05:08 PM |
I believe the 2.0l DOHC usually had an MT75 gearbox fitted to it. The diff is more likely to be a normal not LSD.
[Edited on 18/9/07 by stuart_g]
fesycresy
| posted on 18/9/07 at 05:11 PM |
I've just taken an MT75 out of a DOHC Sierra.
Some have said they have found type 9's in there too.
tegwin
| posted on 18/9/07 at 06:15 PM |
Is there any way of telling which box it is without having to pull it out of the car?..
An ID plate, or something?
And is the mt75 and dohc engine steel or ali?
meany
| posted on 18/9/07 at 06:25 PM |
you can tell just by looking at it...tottalt different.
if it has a DOHC engine it will have a MT75 box...check the link below.
http://www.westfield-sw.co.uk/technical/gearbox/type9install.htm
big_wasa
| posted on 18/9/07 at 06:27 PM |
Ive never seen a T9 in a Sierra fitted with a Dohc only ever the Mt75.
I would put money on it having the Mt75. Being Glx I would also say it will have efi and rear disc brakes. Doubt it will have the Lsd unless some one
has added it.
Imho
tegwin
| posted on 18/9/07 at 06:29 PM |
It does have the rear disks.....Think its EFI as well...
So looks like it might make quite a nice donor...
Completely off the origional toppic, but which Audi V6 will fit the MT75?
UncleFista
| posted on 18/9/07 at 08:19 PM |
Easiest way to find out is to ring the seller and ask where the lever is when in reverse. I can't remember where it is on either (even though
I've a T9 in my car) but I know they're different.
[Edited on 18/9/07 by UncleFista]
Tony Bond / UncleFista
AdrianH
| posted on 18/9/07 at 09:45 PM |
I believe that a type 9 has reverse top left next to 1st.
Also that an MT75 has reverse bottom right under 5th.
R 1 3 5
....2 4...... = type 9
1 3 5
2 4 R ......= type MT75
Dam thing keeps formatting out my spaces!
Anyway that is how I have been checking cars, I want type 9
Adrian
[Edited on 18-9-07 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
James
| posted on 18/9/07 at 11:55 PM |
Er, none will bolt straight together as far as I know.
So that means messing around with bellhousings or adapter plate... in which case any engine of your choice will fit!
- Muhammad Ali
