mattgriffiths2002
| posted on 24/10/07 at 06:04 PM |
Cortina Caliper Bolts and Sierra LSD Bolts Wanted
Hi guys,
Im after a set of (4) front bolts and washers to fit my cortina calipers to the uprights.
Also, I could do with the bolts from a Sierra LSD diff including the bolts from the propshaft joint and the driveshaft joints.
Has anybody got any?
Matt
mcerd1
| posted on 25/10/07 at 07:47 AM |
The propshaft bolts (4 off) are a fine pitched M10, grade 10.9 (I think - will check later if no one else knows)
The driveshaft bolts (24 off for both ends) are M8x50 torx bolts, grade 12.9 - but torx are crap, so just get ordinary 'socket cap heads'
instead should only be a few £
chockymonster
| posted on 25/10/07 at 08:51 AM |
I used High Tensile M10 bolts and Schnoor washers for my calipers on my cortina uprights
