Beardy_John
| posted on 11/11/07 at 07:28 PM |
Sierra Donor
Hi all. Have found a Sierra donor near to me but dont know much about the make/year. Its a 1.6 K reg hatchback with 108k miles, alloys and seems in
good condition. Would anyone know what diff/gearbox/engine its likely to be?? (CVH and Type9??)
Would like to be prepared before I go and look at it  Thanks
big_wasa
| posted on 11/11/07 at 07:35 PM |
Should be the cvh and type 9 but you may get the pinto and type 9
Guinness
| posted on 11/11/07 at 07:37 PM |
No idea!
I bought a '92 j plate Sierra off ebay. Everything on the internet pointed towards it having a CVH and a MT75 box. Bought it sight unseen off
ebay and when I picked it up it had a 1.6 pinto and a type 9 on board.
  Donor!!!
Towards the end of the Sierra's Ford just used up stuff they had on the shelf, and badged them up a special editions.
Still using the alloys though!
Sorry
Mike
Beardy_John
| posted on 11/11/07 at 07:42 PM |
Thanks big_wasa
I've read loads about the Pinto engine and various tuning options, but not much about the CVH. It will still give me nearly everything I need to
start off with anyway. Anything to look out for with the CVH engine??
big_wasa
Ive never seen an Mt75 on anything other than a 2L Dohc.
But as its Ford you never can tell
I think it will be a pinto on a 9
Beardy_John
| posted on 11/11/07 at 07:43 PM |
Is there any advantage between the MT75 and the type9? I know one has a bigger bell housing, but what about the internals?
big_wasa
| posted on 11/11/07 at 07:46 PM |
Smoke on start up is valve stem seals. Cheap easy fix. Heads gaskets.
You wont find an easier engine to work on than a cvh.
Beardy_John
| posted on 11/11/07 at 07:49 PM |
Excellent!! Sounds like a good place for an absolute novice to start
repper
| posted on 11/11/07 at 07:51 PM |
check the breathers thay suffer very badly from wot is none as black death witch is wear thay have been badly manetaned ie not meny oil changers take
off the oil cap look in side with a torch and stick in your finger in and se black your finger is orther than that they are prity reliabull some times
thay rattal and smok on start up but both stem seels and hiydrolic tappets cheet and esey to replace with out removing the head
Beardy_John
| posted on 11/11/07 at 07:56 PM |
Thanks repper,
Again, novice here, what are "breathers"?
big_wasa
| posted on 11/11/07 at 08:02 PM |
Re what "repper" said.
I once did one that was so down on power that you had to slip the clutch in first to get it to pull away.
The breather was blocked. Took the rocker cover of and it was just a solid block of carbon. The cam lobes where round. Still it cleaned up well and
with a new cam it did many more miles ...
TimC
| posted on 11/11/07 at 09:14 PM |
I've just bought a 1.6cvh K-plate 4-door as a daily driver on the basis that if it breaks, I sell the bits.
scotty g
| posted on 12/11/07 at 07:10 AM |
The MT75 is quite a bit bigger than the type9 so may not fit too well in the kit car of your choice but it will take a lot more punishment, having
said that the type9 is plenty strong enough for most applications, both are extrememly reliable.
Whether its a CVH or a Pinto it will definately be a type9 box you have.
Cheers.
Beardy_John
| posted on 13/11/07 at 10:08 PM |
Good News!!
Hi again guys,
Had at look at the beast this evening (in between the drizzle ) and its a Pinto with Type 9 box. Guys has owned it from 6 months old!!!
There seems to be oil residue round the bottom of the rocker cover/top of the head (new head gasket possibly??) and a few other spots around the block
but nothing too major. I am going back for another look in daylight on Sat to see if I can spot anything else.
Are there any areas where oil should deff not be leaking out of on the block, that would mean its a no go???
Any advice eagerly awaited
[Edited on 13/11/07 by Beardy_John]
