Author: Subject: Sierra Steering Lock
MKMike
posted on 2/3/08 at 11:17 PM Reply With Quote
Does anyone know if a transit ignition lock barrel will fit a sierra steering column?
If so,
I'm using a column from a 1985 sierra, what year of the transit will fit?
caber
posted on 2/3/08 at 11:25 PM Reply With Quote
I bought a generic ford ignition lock off ebay that went into my Sierra column, it was listed for sierra and transit if that helps!
Caber
MKMike
posted on 2/3/08 at 11:31 PM Reply With Quote
What year was your column from?
Do you know what year the barrel was ment for?
I know they changed from a flat type key to the round type around 1990, dont know if the barrels are interchangable.
ASH3
posted on 2/3/08 at 11:36 PM Reply With Quote
Yes it will but only if they are the same
style of key an early Chubb lock from a
Transit or Esc will not fit a Sierra housing.
The skeleton type key is known as a chubb and the Sierra type key is known as
a Tibbe either style i can build the lock to
key or sort a key to fit the lock.
MKMike
posted on 3/3/08 at 12:03 AM Reply With Quote
Is the tibbe key the round type?
Mine has the flat type (older style key) is this the chubb key?
My problem is I don't have a key, so I cannot get the barrel out in one piece to get the number from it. So if I could get a new barrel (cheap) with a matching key I'd be sorted.
Their seems to be more transit barrels for sale on ebay so If it will work I'll by one.
posted on 3/3/08 at 09:50 PM Reply With Quote
Heres a pic of the barrel I have, sorry to say its damaged, the locking pin is missing.
Does yours have the M number on it thats on mine? may be able to get another new one if your not in a hurry Rescued attachment Ign Barrell.JPG
MKMike
posted on 3/3/08 at 10:03 PM Reply With Quote
Cheers, no rush.
I haven't got the barrel out yet because I've no key, I should be able to get an old ford key and get it out.
MKMike
posted on 7/4/08 at 09:10 PM Reply With Quote
I got one of the newer type barrels but unfortunatly it will not fit , so I'm still looking for the older type one if any one knows where to get one.
