sammy
posted on 17/3/08 at 08:36 PM |
Volvo 740 radiator dimension
Anyone got the outer dimensions of the Volvo 740 radiator? I can only find dimensions for the core.
Thanks!
Build diaries...
Volvorsport
posted on 17/3/08 at 11:37 PM |
hmm , not sure if it would fit in a +4 , depends on the nosecone your fitting .
ill certainly measure it for you this weekend , itll be around 500mm .
www.dbsmotorsport.co.uk
getting dirty under a bus
sammy
posted on 18/3/08 at 09:24 AM |
Thanks, if it is 500 wide by around 430 tall then it should fit (plus it has the holes at the right ends).
I'm guessing that this would be adequate for the RV8, even if I put a tuned 300hp monster in at a later stage.
Cheers!
Build diaries...
Volvorsport
posted on 18/3/08 at 10:10 AM |
plenty .
