Gergely
posted on 1/4/08 at 11:54 AM |
Sierra drive shaft reconditioning question
Hi, I have push in type drive shafts from the Sierra. They look good and sound. I have cleaned them nicely, and other than replacing the rubber
gaiters I didn't plan to do anything else with them (painting and cleaning of course planned).
But I can not replace the gaiters without taking the thing apart that - as far as I understand - requires to saw through the CV metal shield, taking
it off, taking the CV part apart and then putting back together with new CV shield.
Or is there an easier method to replace the gaiters?
Or should I just take a deep breath and do it properly and clean the internals as well? In which case: what are parts I ned to replace? I guess the
gaiters, the metal shields, large plastic o-rings, gaiter securing clips.
Thanks!
Gergely
locoboy
posted on 1/4/08 at 11:59 AM |
When you'r buying your boots ask for the 'flexi boot' version these will with a bit of persuasion, some lube and a cone of suitable
size slide over the joint from the outer end so you dont have to take the actual joint and balls apart.
If you dont have a cone of the right size you can fashion one drom an ice cream tub or use levers to push it over the joint, dont use screwdrivers -
they hurt your fingers when they slip off
Locoboy
Pdlewis
posted on 1/4/08 at 12:01 PM |
I am doing the later but haing problems finding new shields i have tried stretching the gator over the shield but its not having it
vinny1275
posted on 1/4/08 at 12:11 PM |
It took me about 3 hours to do the boots on mine!
apparently the ford kits come with the metal shields. I had to modify the code I bought, by sawing off the bottom 3 inches so it wasn't too
wide.... that was without the special stretchy boots - turn them inside out, heat them in front of an electric heater, grease the cone and the inside
of the boot well (I used moly grease as I had some to hand, but it was prob. too thick. vegetable oil would probably work well, and isn't black
clamp the shaft in the vice and then put the cone on the end (getting someone else to steady the cone is also useful) and give it an almighty heave. I
felt likt I'd done two hours in the gym when I'd finished
HTH
Vince
Pdlewis
posted on 1/4/08 at 12:34 PM |
I got mine from a ford dealer but they said they can no longer get the original ford parts so i had to have third party which dont come with the
metal.
I got some digger grease yesterday so going to try the heat and stretch method
Gergely
posted on 1/4/08 at 12:40 PM |
Thanks all! Vince I checked your build diary as well and I get it now.
I can also only get third party stuff, so I will try the stretching method.
If it works it will save me plenty of time - especially now the metal shields are completely clean and shiny...
Thanks guys!
Gergely
Pdlewis
posted on 2/4/08 at 05:32 PM |
Id just like to report after an hour with a cone some grease and a heater the net result of stretching a CV boot was it split in half
Gergely
posted on 7/4/08 at 10:54 AM |
Not very encouraging... I have cleaned the half shafts and I will get to the stretching bit this weekend... See what happens... I will report!
