Author: Subject: 4.8 bolt
graememk
posted on 13/5/08 at 03:05 PM Reply With Quote
4.8 bolt
how strong is a 4.8 10mm bolt please
tegwin
posted on 13/5/08 at 03:09 PM Reply With Quote
I caclulate it to be 45000N.....But that figure doesnt seeem right...
www.verticalhorizonsmedia.tv
400N but found this as well.. good luck!
In accordance with BS 3692:2001
The designation system allows the determination of the ultimate and yield/proof strength of the bolt. The designation system is based on two numbers e.g 8.8 . The first number is the tensile strength of the bolt material (N2 )/100. The second number is = 1/100.(the ratio of the Proof (or Yield ) stress and the Tensile strength expressed as a percentage = 100.[Yield (Proof stress) /Tensile strength] /100
The tensile and proof strength of the steel for a 4.6 bolt is therefore calculated as follows
Tensile strength (Rm) = 4.100 N/mm2 = 400 N/mm2 .... Proof strength (R0,2) = 0,6*400 * 100 /100 = 240 N/mm2
SO... 4.8 = 320N
[Edited on 13/5/08 by coozer]
Mr Whippy
posted on 13/5/08 at 03:15 PM Reply With Quote
hmm please don't say you design aeroplanes...
MikeCapon
posted on 13/5/08 at 03:30 PM Reply With Quote
Hi. It's about half the strength of an 8.8.
See here
www.shock-factory.co.uk
matt_claydon
posted on 13/5/08 at 03:32 PM Reply With Quote
The first number is the ultimate tensile strength, in hundreds of Newtons per mm^2. The second number is the percentage (divided by 10) of the ultimate strength at which the material will yield (permanently deform).
e.g. A 4.8 bolt has an UTS of 400 N/mm^2 and a yield stress of 80% of this - 320 N/mm^2.
To actually work out the strength of the bolt you obviously need to multiply this figure by the cross-sectional area of the bolt in mm^2.
For M10 the minor diameter is about 8.5mm so the area is pi * (8.5/2) * (8.5/2) = 57mm^2 so the yield strength is 57*320 = 18000 N or about 1.8 tonnes.
[Edited on 13/5/08 by matt_claydon]
zzr1100rick2
posted on 13/5/08 at 03:37 PM Reply With Quote
About as strong as a hard cheese
stevec
posted on 13/5/08 at 04:36 PM Reply With Quote
You have bought something Chinese I think?
They use crappy bolts like that.
Steve.
balidey
posted on 13/5/08 at 05:12 PM Reply With Quote
Steve.
No, the Chinese make bolts like that, but stamp them 10.9
The sooner the UK gets over the facination of buying cheap sh!te from Asia the better.
iank
posted on 13/5/08 at 05:30 PM Reply With Quote
Throw it in the bin and use an 8.8 or better.
Reusing old knackered weak bolts is a mugs game.
Anonymous
Wadders
posted on 13/5/08 at 05:35 PM Reply With Quote
Strangely enough a lot of structural steel is held together with 4.8 bolts.
Al.
mcerd1
posted on 13/5/08 at 05:38 PM Reply With Quote
^^^^ what he said
some structural steelwork is done with 4.6 and 4.8 bolts - but allot of it is done with 8.8 (all the stuff we make uses 8.8)
I know that ford use a minimum of 8.8 on the sierra's and cossies with critical bolts like the brakes/ driveshafts 10.9 or 12.9
its also worth mentioning that all the above strengths are tensile only - bolts are weaker in shear
in a car alot of bolts are likley to be subjected to impact and other dynamic loads (which are much higher than static loads)
most structural steelwork won't suffer the same kind of impact loads - at least you'd hope not
all the following is from BS 5950:2000 (the main uk structural steel standard)
nominal tension capacity = 0.8 * tension strength * tensile stress area
M12, 4.6 = 0.8 * 240 * 84.3 = 16.2kN
M12, 8.8 = 0.8 * 560 * 84.3 = 37.8kN
M12, 10.9 = 0.8 * 700 * 84.3 = 47.2kN
single shear capacity = shear strength * shear area (normally the same as tensile area)
M12, 4.6 = 160 * 84.3 = 13.4kN
M12, 8.8 = 375 * 84.3 = 31.6kN
M12, 10.9 = 400 * 84.3 = 33.7kN
also bearing strength = bolt diamiter * thinkness of the part * bearing strength
bearing strengths:
4.6 = 260
8.8 = 1000
10.9 = 1300
[btw - I've quoted values for M12 because its the smallest in my book, and as an engineer I'm too lazy to work out the M10 values ]
[Edited on 13/5/08 by mcerd1]
nstrug
posted on 13/5/08 at 07:12 PM Reply With Quote
And remember that the stronger the bolt, the higher it must be torqued: http://www.cncexpo.com/MetricBoltTorqueNm.aspx
Nick
Wadders
posted on 13/5/08 at 08:00 PM Reply With Quote
Funny things bolts, my mate fitted the front discs to his 750cc bike using stainless slot headed machine screws, cos they were shiny and he had some in a drawer.
Despite all the warnings of impending doom and disaster, they proved reliable for at least 40k miles to my knowledge.
Maybe we all worry a bit too much
Personally never use anything below an 8.8 for anything my life depends on.
Al
