PeetBee
posted on 28/11/03 at 11:07 AM |
McPherson Strut Donor Uprights
For those of you wondering what other front struts can be used, there are a couple of methods for using mcpherson struts cut down as used by Dutton
& Sylva (Striker) on mk2 escort struts.
These methods can undoubtedly be reused on other struts which do not unbolt from the upright.
The Dutton uses a maxi balljoint in the top and both reuse the escort TCA on the bottom. Hope this is of interest or help!
PeetBee
posted on 28/11/03 at 11:10 AM |
And the Sylva is below, believed to use transit balljoint as per locost.
Andy S
posted on 4/12/03 at 09:38 PM |
And if you use Capri struts the stub is an inch lower on the strut - effectively lowering the car - and aslo the new Sylva assembly uses a LDV/sherpa
track rod end in a fabricated wishbone to replace the ford TCA - so you have access to fully adjustable suspension.
Both Escort 3/4/5's and Sierras have been modified in a similar fashion
Andrew
