mikeb
posted on 22/5/08 at 06:37 PM |
How to change Sierra Ignition Barrel???
Whats the technique for changing an ignition barrel from teh sierra column.
There seems no obvious way!
I have a new barrel to go in as mine was missing the key.
Helllllllllllllp
mike
indykid
posted on 22/5/08 at 06:46 PM |
you need to turn the key to the second click then push in a sprung detent on the side of the barrel to release it.
if you don't have the key, i believe a 13mm drill bit down the middle works well.
tom
mikeb
posted on 22/5/08 at 06:48 PM |
No key!
what about drilling out the detent?
Mike
tks
posted on 22/5/08 at 07:00 PM |
you will then need a pair of good glasses
read what he said...
mikeb
posted on 22/5/08 at 08:11 PM |
I thought drilling out the detent would be easier than the a 13mm down the main barrel!
All sorted now 10mm and some small pliers sorted it!
Thanks all
Mike
dave1888
posted on 22/5/08 at 09:01 PM |
You need to do both, drill the indent so its below flush with the body then drill out the barel you need to try to get the barrel out so you can turn
it to the second click.
posted on 22/5/08 at 10:10 PM |
You just need to turn the key to I and use a rivit in the hole to release it...
posted on 22/5/08 at 10:11 PM |
Then out it pops and you can see the detent that holds it in.
