Author: Subject: Estate Sierras
eddie99
posted on 28/9/08 at 02:37 PM Reply With Quote
Estate Sierras
Hiya guys, Still searching around for a donor car, hoping to find one this week. From my searching estates generally seem to be cheaper than normal sierras.
Does anyone know the exact differnces between the two. All i know so far is the rear is wider. And obviously, the cheaper the better, so if its just as easy to do with estate. I will look into it further
Eddie
Guinness
posted on 28/9/08 at 03:01 PM Reply With Quote
As far as I am aware there are no differences between the saloon and estate versions of the Sierrra that would affect a locost build.
I think the rear sub-frame is different, but unless you are building a Robin Hood, you won't be using it anyway.
HTH
Mike
Ninehigh
posted on 28/9/08 at 03:02 PM Reply With Quote
From what I understand the vehicle being an estate should make no difference unless you use some parts from the rear i.e. the tail lights. As for it being wider I doubt the axle would be made any different from standard to keep manufacturing costs down. If it is though you'll get a bit more stability through the wheels being further apart :-)
jollygreengiant
posted on 28/9/08 at 03:22 PM Reply With Quote
I think that you will find that it doesn't matter whether its a Sierra/Granada/Salloon/Estate they are all the same width/length of Diff/drive Shaft/Hub.
I used Granada donor on Sierra based kit and needed no modifications at all.
piddy
posted on 28/9/08 at 05:56 PM Reply With Quote
As above rear subframe is different and the spring ratings.
If you use a Granadas they have a 7 1/2" diff.
I had one for my Velocity build but it woundn't fit so had to get a Sierra 7" one
mad-butcher
posted on 29/9/08 at 08:34 AM Reply With Quote
This is from a post from WORX
Diff Codes ( Ford Sierra Diff codes, Differential Codes, Diff Numbers, Sierra Diff )
Ford axle codes
A=3.36 B=3.77 D=3.92 F=3.842 J=4.056 K=3.31 M=3.14 N=4.29 P=3.58 J=3.62 V=3.33 Z=3.59 2=4.27 3=3.62 4=3.82 5=3.26 6=3.12 8=3.56
3,14 CW47-Pin15
3,38 CW44-Pin13
3,62 CW47-Pin13
3,92 CW51-Pin13
3,77 CW49-Pin13 6.5 inch diff
3,38 fitted to 1,6 OHC ECO 5 speed
3,38 fitted to 2,0 OHC HC
3,38 fitted to 2.3 v6 ESTATE
3,14 fitted to 1,6 OHC ECO 4 speed
3,14 fitted to 2.3 v6 SALOON
3.14 fitted to 2.3 Diesel
85GG 4006 DC --- 3.97
85GG 4006 BC --- 3.62
85GG 4006 AC --- 3.38
85GG 4006 FB --- 3.36
87BG 4006 GB --- 3.14
86GG 4006 AAA --- 3.92 LSD
V87BB 4006 BAA --- 3.62 LSD
V87BG 4006 CAA --- 3.38 LSD
85GG 4006 AAA --- 3.36 LSD
Vin plate codes for Diff ratio
Ratio Code
M=3.14 (7" or 7.5"
A=3.36 (7.5"
V=3.38 (7"
U=3.62 (7"
3=3.64 (7.5"
9=3.91 (7.5"
D=3.92 (7"
