Author: Subject: Donor vehicle now won't start - 4.6 rover v8
jimmyjoebob
posted on 14/10/08 at 09:53 PM Reply With Quote
The 1995 4.6 Range Rover HSE auto I acquired for a friends' hotrod now refuses to even crank over. It was driving previously without fault. The engine can be turned over by spanner so isn't seized
How does the gearbox inhibitor switch work on these? I have been told it locks the gearbox in third when stationary if the ecu detects a fault. All the dash lights come on as usual (except the mileage display) but neither the starter nor the solenoid makes a sound.
Any one had a similar problem?
If at first you don't succeed, hide all evidence you ever tried!
Schrodinger
posted on 14/10/08 at 09:57 PM Reply With Quote
Normally with an auto the car must be in nuetral or park to start. and thats where the inhibiter switch comes in.
Keith
Aviemore
meany
posted on 15/10/08 at 11:28 AM Reply With Quote
some auto cars need you to put your foot on the brake aswell
mad4x4
posted on 15/10/08 at 11:38 AM Reply With Quote
P38 Range Rover
Put in Park or Neutral and Turn Key
Check the igintion relays on these
Scot's do it better in Kilts.
jimmyjoebob
posted on 17/10/08 at 06:23 PM Reply With Quote
No matter where the selector is positioned the car won't start.
From a web search the ecu on these has a nasty habit of frying diodes.
