I was wondering which radiators are recommended for a Haynes Roadster.
Aaron
I think they are using VW polo radiators check the haynes roadster forum for the exact mk engine size etc.
Yeah I think you're right the book says Polo, Clio, or similar! I was hoping for peoples ideas based on experience.
Aaron
Yep the smaller of the vw polo radiators, about £30 new on ebay
Yeah think its a 1litre polo one. 400mm rings a bell
I used a Clio one which is a bit bigger and fills the nose a bit more. Have a look at the photos in my galleries.
Dave
Dave
I tried to take photos of all the bits I couldn't find photos of elsewhere!
I think it is a Mk1 but can't remember which engine size. Might have some info at home. The only tricky part is getting the 45 degree hose at the
bottom out and past the frame rails, it is very tight but is possible.
Dave
Dave
I think it is a Mk1 but can't remember which engine size. Might have some info at home. The only tricky part is getting the 45 degree hose at the bottom out and past the frame rails, it is very tight but is possible.
Dave
Dave
You can fit a Merc 190 rad but I can't remember what version.
Edit...
http://www.haynes.co.uk/forums/showthread.php?t=12530&highlight=merc
[Edited on 10/5/13 by Dualist]
he he, yes I am and the buggers get hot, so the bigger merc rad is what I'll be using.
Started my build but not posted on here but the Haynes forum.
Hi,
I have just ordered a Honda Civic Alloy Radiator for my mid engined locost.
One consideration i made was sizing the new rad to the original one. Has anyone considered the engines they are using to the smaller Polo or Cilo
Radiators? What i mean is, is it improtant to get a rad of equal capacity to the original donor car? My Fiat Coupe rad would not fit the nose of my
locost so had to look at alternatives.....
In my car, i will be carrying a lot more coolant than the standard donor, so probaly could afford a small decrease in rad capacity.... however, i have
tried to find a rad that is almost the same size. I do intend running more power than the engine originally produced, so more cooling will be a
requirement.
Will let you know what i think of the Honda rad, believe this is a common option in America....
Rob
